Dyno Sheet Requests
I'm having my motor dyno'd and tuned following a rebuild of my own doing.
Interested to see if anyone has some engine Dyno sheets from a motor of similar shape and size so I can benchmark what I'm seeing from my shop.
3.3L
Stock Ports
Single Plug
SC Cams
GT35R turbo
1.0B
Thanks,
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 10-12-2012, 05:03 PM
Banned
Maybe one on this nine page thread is similar to yours?
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/521544-ultimate-930-dyno-thread.html
Old 10-12-2012, 05:32 PM
Hukdunfoniks's Avatar
Here is the dyno from the same build as yours. I was also running an after market filter/intake and an Andial IC.
Old 10-13-2012, 07:44 AM
Thanks man... let me ask you a dumb question... what are the two sets of numbers on each side? Also was that on an engine or chassis dyno?
Rob Montgomery
Old 10-13-2012, 12:41 PM
This was a chassis dyno measuring wheel horse power. The two numbers are hp and lbft or torque.
Old 10-13-2012, 12:49 PM
That's what i was afraid of... I'm only seeing about 350 at the crank on my build. Waiting for the shop to complete a compression check now.
Rob Montgomery
Old 10-13-2012, 03:38 PM
What IC are you using?
Old 10-13-2012, 07:24 PM
Kokeln
Rob Montgomery
Old 10-14-2012, 07:38 AM
I've gone native
Tt surgeon's Avatar
Headers, exhaust?
Old 10-14-2012, 11:33 AM
B&b headers. Rarlyl8 exhaust.
Rob Montgomery
Old 10-14-2012, 08:25 PM
I've gone native
Tt surgeon's Avatar
You should be seeing 350 at the wheels.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 10-14-2012, 08:46 PM
That was my thought as well. I'm hoping the explanation may be too low of compression. Not so much because I'm looking forward to the expense to remedy that but because its an identifiable issue. Deck height was probably the one area I most likely could have made a mistake in my measurements. I was very focused on making sure that there was piston clearance but didn't confirm actual height. I'm used new factory 3.3 P&Cs.
Rob Montgomery
Old 10-15-2012, 09:25 AM
Post your dyno so we can take a look at it.
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071
Old 10-15-2012, 02:34 PM
I've gone native
Tt surgeon's Avatar
I would start w a compression test.
Old 10-15-2012, 03:20 PM
