proffighter's Avatar
Question EFI Fuel system question
Hi fellows
As you know I am in the middle of the rework of my car and so I make my thoughts about the fuel system. Do you guys with both stock pumps using with the EFI left the stock check valve at the front pump or removed it? And if removed, any differences when starting?
Please share your set-up with me
Roland
930 Turbo '81 Too many modifications to list
Old 11-18-2012, 03:03 PM
With my setup I made no changes other than to remove the accumulator and to re plumb the lines in the engine bay to incorporate the new injectors, adjustable pressure valve, and pressure gauge tap.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 11-18-2012, 04:52 PM
R.I.P.
drmatera's Avatar
Same here, only removed accu
Old 11-18-2012, 04:57 PM
Same here...
just removed accumulator. I have talked to some guys only running 1 pump. (front) Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 11-18-2012, 05:24 PM
Thanks guys
It looks like staying with the check valve is the way to go.
Did you stayed with on recommendation or what reason?
Wonder if anyone tried without...
Maybe I have to make an aluminum version as drilling is a bad idea
Roland
Old 11-18-2012, 11:25 PM
I even kept the accumulator.
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071
Old 11-19-2012, 01:47 AM
R.I.P.
drmatera's Avatar
The accu is nothing more than a shock absorber. I guess it could stay but not sure of it's flow potential for high horsepower
Old 11-19-2012, 02:19 PM
Porschephd's Avatar
You can eave the check valve in at the front pump and loose the accumulator. No reason to leave it in. It is in place to keep the control pressure resting in the CIS head to aid in not vapor locking and leaving you stranded. EFI will not have that problem and is not necessary. You also don't have to use the front check valve but it is not hurting anything and keeps the pumps primed.
Stephen
94 3.6Turbo 6-speed AWD
Old 11-20-2012, 08:42 AM
Accumulator has gone since converted to EFI. There is another check valve, which is inside the pump, so I remove the front one for a try if there is any difference. Unfortunatly I can not test earlier than next spring, as you know my car is knocked down
Roland
Old 11-20-2012, 11:42 AM
Porschephd's Avatar
Shouldn't make much of a difference. You should be able to set the pump prime time in the program.
Stephen
Old 11-20-2012, 06:16 PM
