| onboost |
04-10-2015 06:14 AM |
Originally Posted by onboost
(Post 8569156)
Funny, I just went through this ordeal last month as I continued to receive the wrong header gaskets from several sources after asking them to verify gasket inside diameter before shipment.
I too measured with dial calipers and provided each supplier with those numbers and most thought I was nuts or didn't know what I was talking about.
3.0 was 39mm
3.3 was 39mm
3.2 was 42mm
Mine ended up being 45mm :eek: No it ain't stock
Note correction to 3.0 sizing. since I'm pulling from stuff rambling around in the head, as opposed to running to somebody's book, believe I previously quoted a 2.7 port size..
Originally Posted by Tom F2
(Post 8569950)
Why are the 3.3 larger than the 3.0? Based on the rest of this discussion, I would have expected the 3.3 to be smaller.
Not sure why you would think the 3.3 to be smaller. In fact there has been much discussion regarding the use of 3.2 heads for a number of reasons one of which was to get the slightly larger exhaust port.
If one were ordering gaskets, this is what our host would provide:
3.0 = 39mm - 930-111-191-13 SC & Turbo
3.3 = 39mm - 930-111-191-13 Turbo
3.2 = 42mm - 930-111-191-12 Carrera
