-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   AEM Wideband Location? (http://forums.pelicanparts.com/showthread.php?t=720169)
jpilcher 11-28-2012 07:30 PM
:confused:
I recently purchased an AEM wideband.
I have a 930, with a PowerHaus dual tip exhaust. AEM instructions recommend
that the wideband sensor be located 36" from the turbo. Is it okay to mount the sensor after the muffler?
Thanks in advance
John
unclebilly 11-28-2012 08:54 PM
You don't want the sensor too close to the outlet. At idle, you can get inversion which will give high AFR numbers.
jpilcher 11-30-2012 09:48 AM
The location I was thinking of is about 16-18" from outlet. Any Alternatives?
Anyone running an AEM wideband? If so where do you have yours mounted?
Thanks in Advance.
John
unclebilly 11-30-2012 10:08 PM
Mine is before the muffler on he drivers side in a 2 in 1 out muffler.
mooney265 12-01-2012 05:45 AM
can you get it between the turbo and muffler?
when i moved mine from 12" from tip to between turbo/muffler, my readings stabilized a bunch...
jpilcher 12-02-2012 07:24 AM
Yes, I have about 6" between turbo and muffler. I will try it there.
John
pdqcarrera 12-05-2012 05:20 PM
John
Post a photo when done please.
Miguel Antonett 12-06-2012 02:01 PM
^^^ that's exactly where it should be, between the turbo and muffler.
Moriarty 01-04-2013 02:03 PM
I just purchased a Uego AFR Analog and I was also wondering where to instal the wideband sensor, between the turbo and the muffler isn't it to close from the turbo, any over heat risk for the sensor ?
Norm K 01-04-2013 04:55 PM
Good to hear, as that's exactly where I welded the bung on my new muffler, pending installation.
Moriarty 01-09-2013 02:47 AM
A picture is always better than words, is this location appropriate ? My only fear is to be too close from the turbo turbine with high temperatures.
Anyway difficult to put it elsewhere as well since it will be too far this time ;-)
Thanks for confirming to the french guy !
http://img831.imageshack.us/img831/7572/dsc04432p.jpg
proffighter 01-09-2013 04:36 AM
The place you show is common, but you have to angle the sensor a bit to the outside as recommended by Bosch (15°) etc.. Just like this:
http://forums.pelicanparts.com/uploa...1357734818.jpg
Of course the better way is to mount the sensor more away from turbo, but it's not possible on a 930. Some fit the sensor after the muffler, but as you have a twin outlet, not in your case.
BTW: Be sure to route the cable away from turbine housing due the temps there
Midlife930 01-09-2013 04:41 AM
Here's mine with no issues due to heat and the car is pretty much 100% a track rat. Not too pretty but .........
Davehttp://forums.pelicanparts.com/uploa...1357734977.jpg
jpilcher 01-09-2013 07:13 PM
Thanks Guys, this is awesome.
Moriarty 01-09-2013 10:43 PM
Ok Many thanks to you
