934 cams in 3.3 Motor ???
Trying to pick cams to match my 934 build (show car/occasional track)... so why not pick the obvious 934 cams! . With other upgrades to support these cams, rods, valve springs, rockers,,,efi... etc,,, will they work with stock 3.3 pistons without being modified?
Webcam 934 grind
.406/.406 Valve Lift
278°/278° Duration
254°/254° Duration at @ 0.050
Thanks,
Andrew
9erSport
Instagram @9erSport
Old 04-06-2015, 08:25 AM
3 restos WIP = psycho
kenikh's Avatar
Yes, they will work...934 cams actually don't generate much lift. But there are choices that will give you better low end torque and top end power. There's a recent thread on it, called something like "max hp on SC cams". Check it out.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-06-2015, 08:58 AM
