-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   well - overboost switch (http://forums.pelicanparts.com/showthread.php?t=725384)
Ronnie's.930 12-24-2012 05:01 PM
I unintentionally tested my overboost switch a couple of days ago. I changed the voltage regulator, taking off the Garretson intercooler like I have done countless times over the years, and like some kind of mega moron, neglected to connect the wastegate hose before taking the 930 for a test drive - it quickly overboosted in 2nd gear and I got the "face in the wind shield" experience. Nothing seems to be damaged - runs perfectly, pulls hard, no smoke, etc. (drove it hard for about two hours today) - but who knows. I guess if I am paranoid enough about broken rings I could do a leak down test (but would rather not). I used Racewear studs and rod bolts when I rebuilt the engine several years ago . . . What do you guys think?
The good news is that the thing now charges like it is supposed to - ha!
You can bet I won't forget that hose again!
JFairman 12-24-2012 05:11 PM
I don't think that would have hurt it at all.
I think broken rings happen when someone holds it at too high boost for the timing and fuel being used and detonation is intense and continuous for 2 or 3 seconds or longer at a time.
Ronnie's.930 12-24-2012 05:29 PM
Coming from you, that is music to my ears (eyes)!
gsxrken 12-24-2012 07:06 PM
Makes sense. What would be the point of the over boost switch if, when it kicks in, you're already screwed? No boost signal hose AND a grounded over boost switch = Rebuilding Forum.
DSPTurtle 12-24-2012 07:29 PM
That's why the switch is there. Count your lucky stars and drive that beast.
