Carrera Supercharger installed
Install is complete... here are the details and pics...
'86 Carrera, already had headers, M&K 2in/2out, ARP head bolts, modified cam and chip making 229 HP at the wheels a few years ago on a Dynojet. It is also gutted and fitted with lots of fiberglass for mostly DE duty at 2200 lbs. Additions... Vortech V1 A trim supercharger MSD 6 BTM AEM wideband A/F ratio gauge BOV Boost gauge I made the supercharger bracket myself by layering 1/4" aluminum plates. It is mounted to the engine carrier and is very stable. The stock AFM is on the suck side. The BOV is plumbed from the pressure side of the supercharger back to the input side after the AFM. I started with a vortech 8:1 FMU, but everything went dead rich 10.0 when the boost kicked in. I pulled the FMU and made a few test drives with just the factory FPR and the stock 24lb/hr fuel injectors and to my surprise it works just fine. The AFM seems to communicate to the ECU just fine up to about 3500 rpm (according to the A/F ratio gauge, 14.0~14.5). At 3500 rpm and above it seems the barn door is full open due to the supercharger, but at the same time the factory FPR reacts to the boost and the A/F ratio gauge indicates about 11.5 ~ 12.0 up to 6000 rpm. I haven't notice any difference turning the MSD timing retard knob, but I hope to get dyno time in the next few weeks to get actual data, but so far things are encouraging. I see the boost gauge getting to 7psi before 6000 rpm so I may change the 3" pulley to 3.25" or look into the boost limiter sold by 928motorsports. I was able to get a 0-60 mph pull of 4.78secs per my AIM solo GPS track timer, a full second faster than before the supercharger. Questions, comments??? Thanks, Dan ![]() ![]() ![]()
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now.... '86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Non User
That intake in the cabin must sound sweet, my old supercharged lighting used to suck air like mad when I jumped on it. Any hp and tq numbers now after install?
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
Comments: super sweet
![]() May I ask: How much in parts?
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Trying to schedule dyno time soon, no numbers yet.
Air filter "breathing" sounds nice, supercharger "chirping" is a little annoying, but probably won't notice it much with helmet on! Total cost for parts (drum roll..........) $1650
Prrrrreeeeetttty cool!
And no lag - right? |
Nice clean install, looks great. 4.78 is quick and I imagine that is without killing the 915. If the charge is cool enough you can go to 10psi. Good work and pricing, maybe you could share the mount drawings with those wanting to mount a supercharger, has been a few lately.
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
Sounds like cheap HP. you also make it seem like you just did this in an afternoon - cool
My guess is, you are about 330 CHP ![]() Let us know...
If you have all the main components, fabrication skills and a good local hardware store, it's a 3 day job.
Chain fence eating turbo
Good to see some SC installs after all the boring turbo installs. "A" trim, the one that started it all! It's great to just regulate fueling with either a FMU or how I think you did of using the boost signal only to enrichen the FPR. BTW Protomotive uses ~4:1 ratio for rising rate if that helps, but it sounds you are just fine.
I bet the torque down low is pretty good. |
Grappler
Very nice setup!
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Congratulations! Very important to check the AFRs as you have done. Do you have a tail? Did you have to cut the deck lid?
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
Deck lid was already cut for weight savings
![]() before pic....
Can I ask how did you modify the crank pulley for the supercharger belt, and maybe some more belt details in general?
____________________ 1985 Carrera: Big Reds = Ass Saver |
Certified User
Nicely done and well thought out. This is something I have always wanted to do to a 3.2 or 3.6.
I, and others, would love to see a few more pics of your setup, so don't be shy about posting some more details.
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
I'd like to add that a braided line for the oil squirter would look a lot better.
No change to the crank pulley was required because I am using the same type V belt that the AC compressor used to use. So far no belt slipping that I can detect.
I will post some more close up pics this evening.
Very nice install, and inexpensive! I would love to do this to my 84 Cab at some point. Nice work.
When the common bond is a Porsche, the people who own them are even more interesting than their cars. |
Champagne on Beer Budget
Very nicely done! Just a thought, you might consider replacing the rubber intake 90 in the future with one that can hold up to boost...my 3.2 piece blew out after a few weeks in a turbo application
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
Grappler
That's true. Mine blew out too so I moved to a silicone piece.
