964 exhaust on 930
Will a 964 turbo exhaust fit on a 1979 930.
Thanks, Sloane |
The heat exchangers will bolt on, but the hot are pipes are flared going to the chassis. The 930 version is not flared.
The WG pipe will bolt up, but the tip hits the valence. The catalytic converter will bolt up. The rear muffler will not -- it occupies the space where your oil tank sits.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Metal Guru
993 Bishoff heat exchangers/custom crossover/turbo flange on a 930 is a nice upgrade. Oil lines have to be backdated and the drip tank has to be changed.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
