Porsche Crest Why I get bad gas mileage, Now I know why
Yes I'm keeping my car , thankfully , As some of you remember my trip to TN from DC the best gas mileage could mange was 15.7 MPG at 14.7AFR , yes I could of adjusted my SP to get 15.3 AFR and my MPG would increased a little , by how much, I will test that next time I do a road trip.
The other day I was working on a buddy's stock 930 with the 4 speed trans and noticed that at hwy speed of 70mph the rpms was at 2200. I have G50-01 with 8;32 ring and pinion , at 70 mph i'm at 3000 rpms , I love how close my gears are, but I could use a taller 5th gear , At the drag races I'm just redlining 4th at 7300 rpms at 124mph at theend of the 1/4 mile, I'm good with first thru 4th, my 0 to 60 on a good day is 3.98 , saying that, My city driving I only get at best 11 mpg but sometimes as low as 7mpg and at the track I get 4-5mpg
Right my top speed is 163 at 7300 rpms But I can get there in about a half a mile from a dead stop, but with a taller 5th mile top speed should increase and get better gas mileage, and it would be quieter in the car also at hwy speeds, I guess now I need to find the right gear for my car , I running 285-35-18 on the rears on the street and 315-30-17 on the track, what would be a good 5th gear ? and how much would cost me?
thanks for your support
Helio
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 04-12-2012, 10:30 AM
Crotchety Old Bastard
RarlyL8's Avatar
Helio, while tall gears will help that is not the major problem. My first 915 had short gears and ran 3400rpm @70mph. That setup achieved 20mpg on the highway.
To tune the fuel useage you need a vacuum gage. When at cruize the engine must not just remain in vacuum but you need to tune it as deep into vacuum as possible. The sweet spot will rocket instantly from vac to boost with the move of your big toe.
Old 04-12-2012, 11:13 AM
People here always seem to hate on the the factory 4 speed but for a street car I really like them. Once you get the power levels up the gears don't seem as long and you can stay under boost while the guy next to you loses ground stirring the shifter.
You could also put a taller tire\wheel combo out back to bring the final drive ratio up. You can't lose with 22's!
1987 GP White 930
1977 Ford Bronco
Old 04-12-2012, 11:32 AM
Chain fence eating turbo
Wow, redlining in 4th gear at 124 MPH. My car did not redline (I too have done 124 MPH in the 1/4 mile) and we have the same trans and by your pictures, you have taller tires making this seem even weirder.
It sounds like your trans is geared lower than a stock G-50.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 04-12-2012, 12:26 PM
Hey Brian, how have been, say hi to the family for me,
What you said sounds interesting , your gonna have to explain this better to me , I have not heard of this before, but I am willing to learn. we can do it by phone or here on this thread, and if you have pics or diagrams that would be awesome.how your your doing, have had any more progress since the last time I saw it.
Helio
1992 964 C2 turbo
Old 04-12-2012, 12:31 PM
Hey Tippy,
I have a 8:32 ring and pinion that lowers the gearing a bit, what rpms are you at in 5th at 70 mph? since the only difference of our trans is the R & P that would be good to know. stock tires are 25 to 25.5 inches my new 18s are 26 inches ( but I haven't used them for any racing just for show) and my 17 are 25.7 inches,
thanks
1992 964 C2 turbo
Old 04-12-2012, 12:38 PM
I don't remember off hand what I do @ 70 MPH (my car is not on the road at the moment to test ), but I remember it too was high like yours.
Honestly, I thought it was higher RPM than yours in 5th but 4th in the quarter sounded a lot lower.
Weird.
Old 04-12-2012, 01:12 PM
RarlyL8's Avatar
Family is great thank you. The car hasn't moved in weeks as I have no time for it right now.
As I stated above if your boost gage does not also show vacuum you need to get a vac gage that goes to ~15psi. Note what it reads when you are cruising down a flat road at 70mph. My guess is that you are probably on a very low level of boost which is robbing you of fuel. Another robber is having fuel delivery volume that exceeds what is required, aka flow modification. Safe AFR's can be achieved with stock delivery volume up to ~375WHP when used in conjunction with an adjustable WUR.
Old 04-12-2012, 02:19 PM
Metal Guru
911nut's Avatar
Brian, I'm not aware of a way to do that. Please explain the process. Thanks.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 04-12-2012, 04:42 PM
RarlyL8's Avatar
Timing and fuel, just get out the hotrodder handbook. Same principals that work on a carberated HEI Chebby work on a Porsh.
Old 04-12-2012, 08:43 PM
How can you turn 3400 rpm under throttle and not be making boost? It would seem that you can't push that much air over the hot side impeller without having an effect on the cold side.
Old 04-12-2012, 09:52 PM
Turbofrog
smurfbus's Avatar
It must be also turbine size dependant. Good amount of timing advance helps to keep the heat low but not sure about the best AFR. Over 15 is colder that stoich so if the spark is good enough you can even try 15.5AFR with a lot of advance.
IIRC best economy is around 16AFR but not sure if any 930 runs without bucking that lean?
When I had my timing too retarded I would cruise on boost even at 65mph.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 04-12-2012, 10:56 PM
IMR-Merlin's Avatar
This is what I use for my research when looking for a G50. they have all the gear charts and the have all the gears you will need. I was thinking of going with a taller ring and pinion.
California Motorsports Porsche G50 5 speed transmission section
Glad to hear you're keeping your car.
Brendon
Old 04-13-2012, 08:12 AM
Me too Brendon, Ya i'm familiar with them, Roger at CM in stalled my R & P and sold me KEP clutch , back when I lived in the west coast, I'll have get together with them again. they great to work with,
1992 964 C2 turbo
Old 04-13-2012, 11:10 AM
R.I.P.
drmatera's Avatar
heliolps2 - is your car EFI or CIS I don't remember. It does sound like maybe you are not running enough timing @ cruise.
Old 12-31-2012, 12:35 PM
Tinkering Pays!!
mooney265's Avatar
Mine would be steady at 0.4bar at 3,400rpm. Unless going downhill. Currently, mine is 2,800rpm = 80mph and 0.2bar.
I used to have 8:42 and 80mph was 3,800rpm!! Don't miss that...
Last month, I got 19.5mpg on a 1,200 mile trip at 80mph with stock gearing.
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 01-01-2013, 09:25 AM
Yep, CIS
1992 964 C2 turbo
Old 01-01-2013, 04:53 PM
helio..I have seen you drive.....Lift up on the throttle a bit and you will get better gas mileage..Everything cant be 0-100 all the time and expect good gas mileage... ;-)
Happy New year !
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 01-03-2013, 09:45 AM
Hey , Scott
Very funny man, I do love to see the boost gauge move, ��
1992 964 C2 turbo
Old 01-08-2013, 03:59 PM
