camdon's Avatar
Will a 10 and 12" wide wheel fit a 930?
Just picked up a set of Fikse wheels. I thought they were 9's and 10's. They measure 10 and 12. Will they fit? If so what size tires will I need?
18" wheels
Thanks guys
A few P-cars in the garage
Old 10-27-2017, 08:00 AM
flat6pilot's Avatar
Wide Body
As far as tire size needed, probably 255 and 315. That's what I run on my 10x17, 12x17 Fikse's. Fitment might depend on the offset. My flares are about 2" wider than the turbo flares.
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 10-27-2017, 08:49 AM
hi
they will fit perfect
my wears 12 and 10. i pick up low profile tires to low the car to make a super low car
Old 10-27-2017, 11:32 AM
Titanium User
camdon the width of the wheels are from tire bead to tire bead, not wheel edge to edge. so you may very well have 9 & 10s.
Old 10-27-2017, 11:38 AM
camdon's Avatar
In that case I think you are right. I thought you measure outside to outside.
Here are some pictures I just took. Thoughts?
Old 10-27-2017, 01:00 PM
camdon's Avatar
Kyle.Moty
Those cars are beautiful!
Thank you
Old 10-27-2017, 01:01 PM
camdon's Avatar
If they are in fact 9's and 10's what is the best tire set up to go with? I don't want the sidewall too big,correct?
Old 10-27-2017, 01:02 PM
10/12's
Here are my 10-12"s fit fine...
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 10-27-2017, 02:02 PM
Looking good Phillip.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 10-27-2017, 05:47 PM
camdon's Avatar
Thanks Phillip
Guess I need to figure out what size they really are first
Then what tires sizes. Don't want too much of a sidewall
Old 10-27-2017, 07:55 PM
Crotchety Old Bastard
RarlyL8's Avatar
Wheel width fitment is only part of the package, how well they fit depends on ET and tire size. 10's & 12's will fit if spaced properly with appropriately sized tires.
Your 9's & 10.5's should fit easily if spaced correctly. For tires I would go with 255/40-18 and 285/35-18 but other sizes will fit as well.
As a contrast I modified a set of 3pc wheels to fill up every last mm of space available in the rear. Final result was a 12.75" width (13.25" if measured outer lip to outer lip). This only worked with perfect spacing and a tire size.
Old 10-27-2017, 07:58 PM
255/40/17 in front on one 930, that certainly has to affect(touch) the inside wing and the inside of the passage of wheel when we turn wheels! Otherwise I would put four well tires Sport Cup 2 in 255/40/17 on my wheel rims RUF, they make 9 " in front and 10 " in the back. In Europe it is now very difficult to find tires in 17 "with the good indication of speeds, we have nevertheless the best pneumatic manufacturer to the world! Only and last solution, pass in 18".
Old 10-28-2017, 12:53 AM
RarlyL8's Avatar
If your 9" front wheels are not spaced properly to allow a 255mm width, or the ride height will not allow a 26.5" height at 255mm width then go down one size to a 235/45-18. Spacing is everything both front and back to give you the look you want with no interference. You have the wheels so put them on (with no tires) in the loaded position and you will know what you have to work with.
Old 10-28-2017, 07:15 AM
255/40/17 (63.6cm) is smaller than 235/45/18 (66.9cm).
RUF advised(recommended) me the ride height of 25.2"(64cm) for of 255/40/17 and 235/45/17.
Ideally for of 10 " would be needed 265/40/17 and 9 " 245/40/17.
In 18 " that would be 295/30/18 (in 11 ") and 235/40/18 (in 8 " or 8.5"). We can also put of 245/35/18.
Old 10-28-2017, 09:21 AM
RarlyL8's Avatar
Sorry for the confusion, I was addressing the thread author who has 18" wheels.
I mistyped some of the tire size info on an earlier post (late night should not have been on the calculator). Here are some sizes in 18" that would fit a 9" front wheel and 11" rear wheel and remain under 26" tall:
245/35-18 = 9.64"T x 24.75"T
255/35-18 = 10.04"W x 25.02"T
245/40-18 = 9.64"W x 25.72"T
315/30-18 = 12.40"W x 25.44"
285/35-18 = 11.22"W x 25.85"T
Here is a picture of a set of 9&11x18 wheels that I ran with the 255/35-18 315/30-18 combo:
Also be aware that tire manufacturers have ZERO truth in advertising when if comes to advertised sizing versus calculated sizing. At the 315mm level I have seen 1.0" variation in width from manufacturer to manufacturer.
Old 10-28-2017, 11:41 AM
camdon's Avatar
Thanks guys
Will go with this set up
245 40 and
285 35
Old 10-28-2017, 12:27 PM
full quack's Avatar
Send a message via Yahoo to full quack
Fikse fitment
Well here is mine with 8.5 x 17 fronts and 11 x 18 rears [yes 2 different diameters}
Running 255 40's front, 295 35's rear and you might notice my car is a little lower than most, fits well, drives well, looks are for those to individually determined :}
Old 10-29-2017, 12:36 PM
Tug68's Avatar
I am running 225/40/18 up front(going with 235’s with the next set) and 295/30/18 in the rear. 9 & 10in Fikse. I am running a slight spacer in the rears I don’t remember off hand what size. My rims had a serial # engraved in them and I called Fikse and they gave me tire sizes that would fit the rims and the car. Good luck!
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 10-29-2017, 05:45 PM
camdon's Avatar
Thanks guys. I will try Fikse tomorrow.
Old 10-29-2017, 05:54 PM
RarlyL8's Avatar
Fiske won't give you any info that isn't already listed here. YOU have to decide how tall and wide you want the tires based on what look you are after. The limitations are ride height and offset, both of which only you will know as you have the car and the wheels.
Old 10-29-2017, 06:35 PM
