Is anyone using an aftermarket fuel pump? I am not running CIS, nor am I limited to run factory fuel lines.
The car will have a 500 hp EFI engine and I want to run the correct pump. I will be running all new lines and filters. Anyone have a suggestion on a good in line pump? Thanks in advance Brendon |
I would use the bosch 044.
It is cheaper than oem and delivers more fuel. Used by many here on the board |
E-85 sippin drunk
^^^^ I second that above. I was also thinking about running a Weldon pump that many turbo Chevy world run.... I called Chris at Turbokraft and had a nice chat with him. He recommended (2) 044 pumps... That will give you plenty of headroom and they are E-85 safe....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
I also use twin 044's, plenty of fuel and no issues as of yet.
Just out of curiosity, why not run one big pump instead of 2 044's? I will be building this system from scratch and can update the line size.
Merlin, I can't answer that question, but I will tell you even though your car is apart, it will be a pain to install fuel lines that are significantly larger than the stock ones. That is if you route them as Porsche did. There is very limited space in there.
i am about to embark on the same path , yet did not think the bosch units are e-85 friendly. i also think 2 pumps is out of line. my o2. merlin which filter and micron rate thanks frank
I make 425 FWHP on CIS with a single 044 up front. When I go EFI, I don't see any reason at all to fit another pump. Because the pressure will drop (roughly halve) - the flow will increase correspondingly.
'77 S with '78 930 power and a few other things. |
Tinkering Pays!!
Re: aftermarket fuel pump ??
Sent from my MB855 using Tapatalk 2
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
I would think that a high revving NASCAR engine or a 2000 HP drag car would be running a higher flow rate than a 265 lph 044. If you are fine with the single 044, then why the redundant system with 2 pumps? Is there an issue with pump cavitation and losing pressure under max flow? I am just curious as to the benefits of 2 equal rate pumps performing the same task a 1 higher flow pump. I am running oil lines forward for my oil tank and I could run fuel lines in a new location if it was beneficial. Thanks for all the feedback Brendon |
I will be building my own wire harness from a hybrid between the factory harness and a painless wiring harness. The engine harness is stand alone already, so I want to clean up a lot of the old harness and update to blade fuses.
If you go with an 044 buy it from a reputable source and watch out for cheap ones. There have been many cases of people buying counterfeit pumps that don't perform to spec.
BOSCH 044 real and knockoffs --read this-- - RX7Club.com |
There were a myriad of reasons we chose twin pumps instead of a single. Ground clearance was an issue, also I wanted redundancy built into the system in-case one pump failed. The tuning in the initial stand alone was already dialed in for twin pumps as well. Just made sense at the time. I also have used Walbro 255's in previous projects with success as well. All up to preference I guess. |
Chain fence eating turbo
Twin Bosch -044's here too with EFI.
It's factory fitment on GT3's. It was factory (albeit a different factory) fitment on 500+HP Cosworth's. The WRC rally guys use them. It's widely used in motorsport. Quote:
Using two lower spec fuel pumps - as they factory did - enables them to meet both requirements. But EFI more typically runs at 3 bar than 8 bar. Fitting two pumps - in series - if one will do the job increases, not reduces, the chance of failure. What happens if a pump dies? Exactly the same as the overboost protection kicking in. You have a pump forcing gas through a dead pump. Or a dead pump at the tank restricting flow to the good pump. You're in limp home mode. The WRC rally guys and the endurance racers run multiple 044's - but they're in parallel. Because a single pump will do the job, and the extras are there for redundancy.
Running pumps in series increases volume and helps maintain pressure at a higher demand. They're essentially helping each other. |
I remember that VW had some issues with tank pumps going bad in their Golf MKII cars. The cars would go lean and die. I would hate to see the AFR when that happened under boost. I guess a fuel gauge with a low pressure warning light would remedy that though. Thanks again for the input. |
Not the NASCAR Grand National Series cars that I worked on. But that was many moons ago.
There are electric fuel pumps with greater flow, but they are expensive, or noisy as hell (Aeromotive)!
Put an -044 inside the stock 964/993 rubber housing and it's dead silent, reliable. In-tank application: -040.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
