-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Stock or performance upgrade. (http://forums.pelicanparts.com/showthread.php?t=747446)
websjk 04-30-2013 05:44 PM
This may be the wrong area for this. Was not sure where to ask.
I have a stock 1978 930 and it needs a few new exhaust parts. Is it better to keep it stock or go with Fabspeed header system with heat exchangers.
Will it decrease the value of the car not going with stock parts??
Thanks for input.
WPOZZZ 04-30-2013 05:46 PM
Put the exhaust as you'll have more fun, but keep all the stock parts.
oilonly 04-30-2013 06:58 PM
Struggled with the same question myself. Ended up going with the aftermarket upgrades in my sig below. Saved all the existing stock stuff for future use if I ever want to slow the car down again.
mark houghton 04-30-2013 07:39 PM
And that just about sums it up. After tasting what simple modifications can do, going back would make one wonder about one's sanity. At that point the addiction would have deep hooks into you....no looking back....unless there's a buyer that just must have mediocre performance (by comparison, anyway).
Save the parts, just in case. Many of us have garages full parts for that eventuality. With any luck I'll die before I have to grapple with that decision, and let my heirs worry about it.
websjk 04-30-2013 08:03 PM
Thank you for the input. That was the way I have been leaning. It is hard to believe that upgrades can devalue the car. I will keep the old part in the attic above the garage. I have been struggling with this for a while. Stock or make it run like it was designed to.
websjk 04-30-2013 08:13 PM
What is the best aftermarket exhaust to install with heat exchangers.
NeverL8, Fabspeed, GHL, BB???
Roby466 04-30-2013 08:19 PM
I was told that if heat is very important (like it is for me as I live in Canada), to go with a set of 993 (sorry for the previous mistake here) heat exchangers with flanges reversed (for 930 application), talk to Rarlyl8 and he can supply the pipe that will connect the two sides to the turbo flange with waste gate flange and get his muffler, he has very nice stuff... I'm working on that setup. I got all the parts except the new oil catch can and I can't wait to install it all.
Good luck
zakthor 04-30-2013 08:22 PM
I made the switch to carerra heat exchangers when I got my car (actually they came off a 91 turbo). Difference was:
Before: the car had no power, no power, and then oh **** oh ****!
Now: more power everywhere but the transition to boost isn't as frightening. Faster and more drivable but also more sane.
oilonly 04-30-2013 08:24 PM
GHL is out of business, the others you mentioned are fine, RarlyL8 sells an optimum set but it will cost you more.
infraredcalvin 04-30-2013 08:50 PM
Originally Posted by Roby466 (Post 7416392)
I was told that if heat is very important (like it is for me as I live in Canada), to go with a set of 996 heat exchangers with flanges reversed (for 930 application), talk to Rarlyl8 and he can supply the pipe that will connect the two sides to the turbo flange with waste gate flange and get his muffler, he has very nice stuff... I'm working on that setup. I got all the parts except the new oil catch can and I can't wait to install it all.
Good luck
Isn't this done with 993 heat exchangers?
websjk 05-02-2013 06:48 AM
How much work is it to make the 993 heat exchangers work with the 930. That sounds interesting. Do I have to do welding? I might be interested in this.
I was also looking at the after market systems and it looks like all the mufflers do not have an input for the waste gate output? Where does this go and is it loud?
jsveb 05-02-2013 10:00 AM
I think you have to rotate the flanges. Brian, rarlyl8, and Ben have done this. I would get in contact with him. They used to sell the required u-pipe as well.
Simon930Berlin 05-02-2013 12:05 PM
<rant>
Eehm, thats the same.
Keep it stock. These old cars have been designed in a way that is what it is.
For more bang for the buck buy yourself a Mitsubishi Lancer Evo X - and maxx it out. No loss there.
IMHO 930's are pop-cultural assets, that deserve to be kept as they are... And who needs more power, and in what circumstance, with a 30+ years old car?
</rant>
Simon930Berlin 05-02-2013 12:06 PM
(End of rant : )
Roby466 05-02-2013 12:43 PM
Sorry, I typed the wrong number... (corrected now) It is 993. I purchased mine already switched from a guy here, they appear in the for sale section once in a while. Rarlyl8 will have the rest you need.
zakthor 05-02-2013 05:42 PM
For those that are in favor of stock: Do you mean you think folks should maintain the stock usa exhaust? Didn't the EURO 78 and 79 come with the reasonable Carrera style exchangers, so using them matches the designer's intent?
Rant:
Stock in this case is really bad, especially the heat pumps which are objectively evil and must be destroyed! :)
Here is photographic proof of how much the stock headers suck, just imagine the gases fighting their way through them. You can keep your original headers in a box for the next owner so he can enjoy the car as original.
http://zakthor.files.wordpress.com/2...5.jpg?w=700&h=
http://zakthor.files.wordpress.com/2...0.jpg?w=700&h=
zakthor 05-02-2013 05:46 PM
And for comparison here's the later headers:
http://zakthor.files.wordpress.com/2....jpg?w=1000&h=
RarlyL8 05-02-2013 07:55 PM
That picture above is the exhaust system for a 965, not 930, but is very similar in appearance.
The question of value goes away if you keep the stock parts. All this is bolt-on so can be changed back in an afternoon. Many times we have removed the stock system, sand blasted and painted it then boxed it up for storage. If and when the car sells the OEM system will be in very good condition and add to the value. In the mean time you get to enjoy the car.
I might suggest you look at true performance systems, unless of course you just like heavy shiny stuff. ;)
