Head to Cylinder Seal?
On my recent rebuild the shop told me to use Copper Coat on the mating surface between the head and the cylinder. Now that I have the engine apart again for a broken stud and cleaning up the remains of the Copper Coat I wonder how effective this is. What are others doing that have not fly cut and installed gasket seals? Thanks for any and all suggestions.
Old 04-26-2013, 06:28 AM
totle's Avatar
Install dry. No gaskets or copper coat.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 04-26-2013, 07:26 AM
CaptainCalf's Avatar
+1, I don't think a gasket or copper coat would help any if a head decided to lift and shuffle around under high boost, but flame rings would
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 04-26-2013, 07:54 AM
Ken911's Avatar
either cut them for flame rings or some shops lap the cylinder to the head with lapping compound. Imagine Auto used to do that.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 04-26-2013, 09:13 AM
Where are the flame rings available? Thanks,
Tom
1972 911T (with 3.2), 1985 930-EFI Conversion (in progress), 2016 Cayman GT4
Old 04-26-2013, 01:54 PM
sjf911's Avatar
Tom
TurboKraft did mine and then recommended lapping.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 04-26-2013, 02:52 PM
Do you use common valve grinding compoud to lap them? If not what do you use?
Old 04-26-2013, 04:46 PM
sjf911's Avatar
Yes, valve lapping compound (fine) with the rings removed.
Sapere aude
Old 04-26-2013, 04:54 PM
Thanks, thats what I figured.
I'm guessing you put some on the surfaces and with light pressure rotate the head or cylinder back and forth by hand for a minute or two or until there is a nice uniform freshly lapped grey finish on the entire sealing surface where the head and cylinder meets.
Then wash it off of course.
Old 04-26-2013, 05:07 PM
sjf911's Avatar
I think marking the surfaces with machinist's dye was recommended but I basically did exactly as you wrote.
Sapere aude
Old 04-26-2013, 06:16 PM
beancounter
jwasbury's Avatar
This is exactly what I was told to do by a reputable Ducati shop when I was reassembling my 900cc Duc engine after head stud replacement. Ducati engines are similar to the Porsche in that they do not use any head gaskets.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 04-27-2013, 03:34 AM
Smart quod bastardus
fredmeister's Avatar
I used a scotchbrite pad and rotated the cylinders on it until they cleaned up nicely then used the pad on the head surface with my finger in the sealing area.
This is not so aggressive to scratch the surface but does nice to clean it up.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 04-29-2013, 09:59 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Whether you have flame rings or not..... If.... you lift a head you will have the same results. A freshly machined set of mating surfaces lapped, will give you the best sealing. More surface mass area for sealing. If you run a gasket of some sort and lift a head the gasket can become damaged and ultimately top end tear down will be necessary for repair. There are ALOT of BIG HP guys running lapped cylinders without rings. Just saying....
It changes from time to time.....
Old 04-29-2013, 01:37 PM
Chain fence eating turbo
Exactly what I did too.
Old 04-29-2013, 09:29 PM
Ken911's Avatar
me too then i lapped them in with valve grinding compound
2019 Silverado 6.2L
Old 04-30-2013, 07:20 AM
Scottsdale Arizona USA
Its important to have at least the 3 slugs on that side resurfaced and verified the same height. If the ni-resist rings and grooves are added, then resurfaced with machined precision, you shouldn't have to do any lapping.
Just tell your machinist these parts are going on the next Mars Rover so they have to be clean and tight!
This latest engine project had some divots and uneven surfaces.. which means you have to take off more material to get min clean up.
Here is some eye candy complements of PMS:
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design
+1 (844) URO-PART // modepw@europartswest.com
Old 04-30-2013, 09:44 PM
Can you show an example of a mild case that needs work (before its machined) to give us an idea of whats not acceptable and when clean up is going to be required?
It would be great to have a benchmark to know when one can skip this and save some time and money or when its needed for a successful build.
Not being in the biz and seen alot of damaged heads before its hard to make the call if you're a guy like me doing this himself.
Thanks for your experience,
Fred
Old 05-02-2013, 09:34 AM
