iamchappy's Avatar
AFR reading between shifts
My LC-1 appears to be working correctly up until i shift, then it pegs at 18 for a second or two before returning to normal.
Could this be caused by flames shooting out my tail pipe . My sensor is located about 22" downstream of the turbo and about 16" from the end of the tail pipe.
I dont know that flames are but I could hook up the Go-Pro to check and see.....
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 07-11-2013, 11:06 AM
Chain fence eating turbo
Raw fuel will actually read as no fuel, so yes, that may be it.
I don't know if CIS has a fuel shutoff as that can be it too.
Old 07-11-2013, 11:32 AM
proffighter's Avatar
EFI or CIS?
However, here is what happens when I shift:
Roland
930 Turbo '81 Too many modifications to list
Old 07-12-2013, 12:44 AM
Ken911's Avatar
Sometimes when it backfires and pops during decel and between shifts when the gas ignites and explodes out of the tail pipe air rushes in backwards which will also give you a signal like that. Mine has a dual out and i have to block one of the pipes to even get a steady reading during idle.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 07-12-2013, 06:34 PM
mark houghton's Avatar
I believe you've hit on it. I laid awake last night trying to puzzle this out.
Remember that these O2 sensors for the AFR gauges are reading the amount of oxygen remaining after combustion. If you're reading high AFR's, that means that there is excess un-consumed O2 still available (in other words, not enough fuel to consume all the available O2). One would think that in the case of excess fuel in the exhaust system (i.e, muffler) there won't be enough O2 present to completely burn all the fuel...i.e, all the O2 has been consumed trying to combust all that extra fuel...which means a low AFR reading 'cause there aint no oxygen remaining but just a bunch of raw fuel drooling out the exhaust pipe after it's done blowing flames. So the only way for a high AFR would be if fresh air were to be re-introduced between shifts.
My AFR sensor is located about 11" inside of the exhaust tip, and yet I don't see the AFR's peak lean between shifts (actually, just the opposite as the throttle plate closes and restricts any more air from entering the combustion chambers). But then I'm not running pig rich on boost either and as far as I know I'm not shooting flames. I usually look straight ahead when seriously 'getting it on', not really caring what's going on behind the car.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 07-12-2013, 06:50 PM
Ken911's Avatar
mine spikes every time i shift. the sensor is located about 6 inches from the end of one of the tail pipes. right after the emptybox/muffler.
2019 Silverado 6.2L
Old 07-12-2013, 06:54 PM
cliyde's Avatar
Normal behavior on my 3.2T when the throttle plate closes - no fuel , no combustion, only O2 flowing through. Also, fuel injectors will turn off until the rpms return below 1000 RPM.
G-Body 3.6 Transplant
Old 07-12-2013, 07:50 PM
gavinc69's Avatar
Mine also does the same thing, AFR jumps about showing 14+ to 15+ on down shifts as its popping.
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 07-13-2013, 01:47 PM
non-whiner
mreid's Avatar
That's normal. If EFI, the ecu will also shut off fuel as it reads a high vacuum with no load.
"Too much is just enough."
Old 07-13-2013, 02:07 PM
