82 930 is bucking....
While cruising seems like car is losing fuel pressure, and load buzzing noise coming from the rear. Fuel filter is new(did full tune up).
Fuel pump?
Old 11-09-2011, 04:23 PM
Tinkering Pays!!
mooney265's Avatar
There are 2 fuel pumps... one between the front tires [by steering rack] and the other by left rear wheel...
You could turn on key, unplug blue/green connector at rear of CIS metering plate [plate sensor] and walk around car listening for both fuel pumps...
Let us know...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 11-09-2011, 04:38 PM
Rear pump buzzing really loud? Anyone here have detailed instructions on replacing rear pump.
Old 11-09-2011, 04:40 PM
DSPTurtle's Avatar
Tap it with a hammer and see if it will start pumping.
Oh yeah, to answer your question... take off the left rear tire. Grab a 10mm wrench and unbolt the two nuts holding the pump in. Lift up, twist and slide the pump towards you and use a 15mm (I think) and take the two fuel lines off (on one the back and one on the front). You need a 7mm and 8mm to pull the wires. Installation is reverse of removal. Should take you all of 1/2 hour. Most of the time spent taking the tire off and back on.
Oh yeah, make sure you have the new fuel pump in hand before you start
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 11-09-2011, 04:51 PM
Thanks you very much!
Old 11-09-2011, 05:05 PM
Replaced rear fuel pump and still having same problem. Any thoughts?
Old 11-16-2011, 07:54 AM
mark houghton's Avatar
Allow me to do a listening check on this. Your words "a loud buzzing sound from the rear", and we jump to the conclusion that it must be the rear fuel pump. Galileo, did you confirm that it was indeed the rear pump that was buzzing, or just assumed and replaced it anyway...and still hear the buzzing? Maybe it's not the pump at all.....
Other things that buzz - well, I can think of one. If your car has the oxygen sensor/Lambda control system for emissions control, there is a frequency valve that oscilates in response to the signal it gets from the O2 sensor and computer. That freq valve is located behind and at the base of the fuel distributor (toward the front of the car...almost inaccessible). They make a constant buzzing sound that can clearly be heard without the engine running (but not so easy to hear with the engine running). Just a thought, probably not your issue, but if you had something odd going on with that control loop or it's components, it would mess with your mixture and may cause the poor running you're seeing.
So why would a brand new fuel pump buzz like a bee hive? Hmmm...
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 11-16-2011, 10:07 AM
Buzz
If the car is running and the rear pump is noisey the problem may be that the front pump is not running and causing the rear to cavitate and not produce the pressure it should.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-16-2011, 11:34 AM
Alan L's Avatar
And it may not be the pump, but the relay.
One might hope the area of the buzzing could be narrowed down a bit by following the audible trail. But you could try swapping the two fuel relays in the fuse compartment up front - swap them over and see if the noise moves rear to front. Or goes away - as the front pump kicks in and the rear remains silent.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-16-2011, 11:50 AM
THAT is a very good point and possibility!
Old 11-16-2011, 12:52 PM
Looks like it was the relay after all! You guys are great, thanks!
Leo
Old 11-16-2011, 02:26 PM
Alan L's Avatar
Leo
Rather late in life, I have concluded that is why Pelicans were put on this earth. To serve a purposeful life up fixin der Porsche.
Alan
Old 11-16-2011, 02:32 PM
Well that's a pisser....spend the $$ on a new pump only to find that a fraction of the $$ for a relay fixes things.
I've got spares rattling around in my glove box - amongst other "just in case" things.
Old 11-16-2011, 06:07 PM
DSPTurtle's Avatar
Hey Leo,
Send me your old pump so I can test it
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 11-16-2011, 06:23 PM
Thanks!!
A bit of an old thread, but it helped me out. I was teaching my daughter to drive my 87 930, and the next day I had this exact problem. I think it was all of the on and off of the key that must have caused the relay failure. I was able to replace the front pump relay with the AC relay which was the same, and the problem was solved.
Old 07-23-2013, 08:46 PM
