-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Is this bad or really bad? (http://forums.pelicanparts.com/showthread.php?t=767029)
skimp930 08-20-2013 04:43 PM
A few months back a green light came on my dash and I had no idea what that was. The light was green so I thought, Hay it's telling me all is well...so I thought. My rpm needle started jumping which told me my alternator is on the way out. Decided to swap out my alternator and after I removed the fan housing here's what I saw...
http://forums.pelicanparts.com/uploa...1377041147.jpg
http://forums.pelicanparts.com/uploa...1377041178.jpg
http://forums.pelicanparts.com/uploa...1377042110.jpg
http://forums.pelicanparts.com/uploa...1377042127.jpg
To all the experts out there, how bad is this? Should I go ahead and sell one kidney or both? :mad: This can't be good. Any suggestions on next steps I should take?
Also, here are some pics of the wiring to the alternator. The black wire looks a bit crispy. Was thinking about wrapping it with electric tap and hope nothing happens but wanted people's thoughts. I appreciate the help.
http://forums.pelicanparts.com/uploa...1377041976.jpg
Thank all,
Sean
quattrorunner 08-20-2013 04:59 PM
For one, I'd replace the ground with new(easy).
And I wouldn't worry too much about the engine unless it's leaking combustion pressure as well. Hows it run? I'd have a compression test and leakdown just to see. I'd doubt it hurts anything though.
Miguel Antonett 08-21-2013 05:11 AM
^^^ +1.
The harness looks pretty cooked - they all look after 30 years of heat cycles. Do a leak test to find out how bad the leak is. It doesn't look that bad. BTW, the green light was/is the alternator.
6771911esses 08-21-2013 06:26 AM
Broken stud? Try tightening the heads studs on that cylinder and see what happens. If broken, I would get it fixed. Ground strap I would replace. It may cause funky starting, erratic tach, and other electrical gremlins.
ficke 08-21-2013 07:19 AM
I will add my two cents.
You were not worried about the engine before you saw this? So find hard evidence of a problem before you worry about it now.
Remove the valve covers on the offending side and see if there is a loose head stud by just hand tightening with a ratchet and socket. If there is a finger tight nut then you have a problem if not go back to driving the car and not worrying about it.
As for the ground strap that is missing some insulation, non issue, that is a ground strap if it happens to ground more fine. I am sure there are more important things to do with your money on your car than the ground strap?
xbmwguy 08-21-2013 08:24 AM
i think you are fine on the oil sweat, as others said check head bolts. the ground should def be addressed, as these cars are extremely ground sensitive. easy cheap fix
Spenny_b 08-21-2013 10:42 AM
My 2p....when I pulled my engine, it was FAR wetter than yours looks to be, and I wasn't concerned about it's state of health either (I pulled it to do an EFI conversion....and ended up tearing it down anyway!). Once pulled/stripped, everything was fine....seems to be par for the course with these lumps.
Personally, I would replace that ground wire - easy to do while you've got the alternator out, PITA if it is suspect, and starts doing weird stuff later on.
skimp930 08-21-2013 11:31 AM
Thanks for the suggestion guys. I guess I'm not used to cars leaking oil and I freak everytime I see something like this. For the past few months I been upgrading/replacing as things come up. It all started when seals on my turbo went south and was replaced with GT35R. Brian at Rarly8 rebuilt my fuel head / WUR and order the RPM switch, which should be here shortly. I hope a broken head stud is not in my picture but I'll check them out. Again, thanks for the suggestions. Any pointers as this is the first time I'm checking/retorque the head studs? I found some info on torque figures through the search feature but not 100% sure how to access the head studs. I'm assuming it's a matter of draining the oil, removing the valve covers (as ficke mentioned) and then retorquing the head studs? I'm also assuming I will have access to the head studs when I remove the valve covers. Please correct me if I'm wrong.
Thanks,
Sean
quattrorunner 08-21-2013 11:44 AM
Thanks,
Sean
Once the valve covers are removed the head studs are available. grab a torque wrench and tug on them to see if they're tight. If not, see if they'll tighten down rather than pull out. If they're not tight and not broke, they will torque in most cases so don't worry.
skimp930 08-21-2013 12:34 PM
Thanks for the info quattro. I'll check them out.
Spenny_b 08-22-2013 04:04 AM
No need to drain the oil mate, 99% of it will be back in the oil tank and in the feed/return pipework...you'll prob get some residual oil coming out of the lower exhaust valve covers, but most of it should've drained back to the crankcase via the drain tubes (2 per side on the underside)
Ken911 08-23-2013 07:57 AM
If you want the green light to go away turn off your fog lights lol the blue one is high beams the green one is fog lights.
T77911S 08-23-2013 08:13 AM
i would do a compression and leak down test.
just put a ratchet on the head bolts and give them a little pressure. if it is broken, you will know it. dont ttry to check it at the torque setting
quattrorunner 08-23-2013 10:41 AM
Why not? If there is a problem it's already there. If it's not torqued it should be.
Ronnie's.930 08-23-2013 10:50 AM
Brando, there are engine builders that say you should not touch old Dilivar (sp?) studs due to the risk of snapping them.
quattrorunner 08-23-2013 10:55 AM
Makes sense.
Perhaps some JB weld then?
Ronnie's.930 08-23-2013 11:01 AM
Originally Posted by quattrorunner (Post 7617917)
Makes sense.
Yep, and LOTS of it! :D
DohertyCM 08-23-2013 05:31 PM
JB weld?
No JB WELD...no need for it.
the head studs need to be checked...if one is broke you will find it.
Re-torque as the manual states and move on.
Clean the engine up and make sure it really is leaking...maybe it is not now.
GET A NEW GROUND STRAP!!
Ronnie's.930 08-23-2013 06:42 PM
The JB Weld comments are a little joke that Brando and I have been batting around for a year or so (not actually recommending the use of it here).
DohertyCM 08-24-2013 08:40 AM
JB Weld
Funny!
