Turbofrog
smurfbus's Avatar
Has anyone run turbo with an early rear bumper?
Looks like it might be too tight to fit a turbo behind it ? I like the minimalistic look of the early bumper.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 08-25-2013, 11:46 PM
totle's Avatar
Remember there was a pelicanite that posted a picture of a pre-74 with a 930 engine fitted under the ducktale .
Did a search and there is some picture in this thread.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/475359-ducktail-930-a.html
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 08-26-2013, 03:43 AM
Turbofrog
smurfbus's Avatar
I already have a flat lid and a ducktail and both fit but how about the bumper?
Old 08-26-2013, 06:27 AM
onboost's Avatar
Yes, they're are a couple of those around.. however, fitment on every car is going to be a little different.
Of course you do know;
- You will need to remove your reflector box from the tub to fit up the early style bumper.
- Your best bet for a bumper source is going to be MA Shaw or GT-Racing
RGruppe #180
Old 08-26-2013, 10:46 AM
Turbofrog
smurfbus's Avatar
I think I would also have to run zork or something very small on exhaust side. Maybe too much work and a bit unreversible regarding the reflector base.
Old 08-26-2013, 10:58 AM
onboost's Avatar
Its reversible if taken out properly, but its work to do so, and more work to properly put back and re-finish.
RGruppe #180
Old 08-26-2013, 11:39 AM
It fits but is a bit exposed. I think it looks mean with the exposed headers, reminds me of the 2.1 turbo RSR. I have RarlyL8 headers and muffler with custom wastegate dump and tail pipe.
Old 08-26-2013, 07:41 PM
Turbofrog
smurfbus's Avatar
Nice, do you have bolt on reflector base or is it welded? Any pics of it?
Old 08-26-2013, 08:35 PM
Here's mine with a Monty dual out muffler.
Brooke
1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black)
1952 MG TD with F20C
Old 08-26-2013, 10:07 PM
trans
This is a bit of a hijack,sorry OP, but what trans are you using. I have an opportunity to put a 3.3 Turbo in my longhood.
John
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 08-27-2013, 02:54 AM
Not sure I understand, are you talking about a heat shield? Only thing I have is a reflective heat blanket attached to the backside of the license plate panel.
Old 08-27-2013, 06:58 AM
John
Aluminum case 915.
Old 08-27-2013, 07:00 AM
Turbofrog
smurfbus's Avatar
Reflector box onboost was refering to.
Old 08-27-2013, 07:47 AM
His is a true early car, so it never came with a "Porsche" reflector panel. To fit an early car rear bumper, you'd need to remove the sheetmetal piece between your tail lights.
Have you ever considered using an IROC rear bumper? Would bolt up with no modification, you loose the clumsy rubber bits from the impact bumper too.
Old 08-27-2013, 09:31 AM
Turbofrog
smurfbus's Avatar
yes about the IROC ; )
From 930
Old 08-27-2013, 09:52 AM
copbait73's Avatar
Yes, it can be done but there is very little room for anything that does a really good job muffling.
Don't put an IROC bumper on a longhood or vice-versa, that is model year mixing and doesn't match well with the rockers and front bumper.
Old 08-27-2013, 10:47 AM
Turbofrog
smurfbus's Avatar
Yeah, you might be right about the over all look with mixed parts.
Old 08-27-2013, 11:42 AM
Smurfbus,
Is there a thread about your intercooler setup you can point me to? I would like to go without a tail on my car, but would prefer to keep an intercooler.
Brooke
Old 08-27-2013, 01:29 PM
Turbofrog
smurfbus's Avatar
No thread but Chris at Turbokraft said it was an one off and NOT something they will recommend performance vise as its so thin to fit under the plain lid. But its fine for me and if I see performance loss I will connect again my water meth. I just tried 1 to 1.1bar and all went well and logs were a bit on the rich side so I will iterate until its fine in all gears and rpms.
The last change I made dipped the torque peak area under 11AFR to 10.3AFR so its a bit harsh adjustment but I hope to get a good compromise.
Here is the pic from the last owner.
Old 08-27-2013, 08:54 PM
