-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Has anyone run turbo with early rear bumper? (http://forums.pelicanparts.com/showthread.php?t=767873)
smurfbus 08-25-2013 11:46 PM
Has anyone run turbo with an early rear bumper?
Looks like it might be too tight to fit a turbo behind it ? I like the minimalistic look of the early bumper.
http://forums.pelicanparts.com/uploa...1377276202.jpg
totle 08-26-2013 03:43 AM
Remember there was a pelicanite that posted a picture of a pre-74 with a 930 engine fitted under the ducktale .
Did a search and there is some picture in this thread.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/475359-ducktail-930-a.html
smurfbus 08-26-2013 06:27 AM
I already have a flat lid and a ducktail and both fit but how about the bumper?
https://lh5.googleusercontent.com/-0...0/DSCN0170.JPG
onboost 08-26-2013 10:46 AM
Yes, they're are a couple of those around.. however, fitment on every car is going to be a little different.
Of course you do know;
- You will need to remove your reflector box from the tub to fit up the early style bumper.
- Your best bet for a bumper source is going to be MA Shaw or GT-Racing
smurfbus 08-26-2013 10:58 AM
I think I would also have to run zork or something very small on exhaust side. Maybe too much work and a bit unreversible regarding the reflector base.
onboost 08-26-2013 11:39 AM
Its reversible if taken out properly, but its work to do so, and more work to properly put back and re-finish.
LS1951 08-26-2013 07:41 PM
It fits but is a bit exposed. I think it looks mean with the exposed headers, reminds me of the 2.1 turbo RSR. I have RarlyL8 headers and muffler with custom wastegate dump and tail pipe.
http://forums.pelicanparts.com/uploa...1377571044.jpg
http://forums.pelicanparts.com/uploa...1377571301.jpg
smurfbus 08-26-2013 08:35 PM
Nice, do you have bolt on reflector base or is it welded? Any pics of it?
rswannabe 08-26-2013 10:07 PM
Here's mine with a Monty dual out muffler.http://forums.pelicanparts.com/uploa...1377579950.jpg
http://forums.pelicanparts.com/uploa...1377579987.jpg
sundevil64 08-27-2013 02:54 AM
trans
This is a bit of a hijack,sorry OP, but what trans are you using. I have an opportunity to put a 3.3 Turbo in my longhood.
John
LS1951 08-27-2013 06:58 AM
Not sure I understand, are you talking about a heat shield? Only thing I have is a reflective heat blanket attached to the backside of the license plate panel.
LS1951 08-27-2013 07:00 AM
This is a bit of a hijack,sorry OP, but what trans are you using. I have an opportunity to put a 3.3 Turbo in my longhood.<br>
<br>
John
Aluminum case 915.
smurfbus 08-27-2013 07:47 AM
Reflector box onboost was refering to.
will hung 08-27-2013 09:31 AM
His is a true early car, so it never came with a "Porsche" reflector panel. To fit an early car rear bumper, you'd need to remove the sheetmetal piece between your tail lights.
Have you ever considered using an IROC rear bumper? Would bolt up with no modification, you loose the clumsy rubber bits from the impact bumper too.
smurfbus 08-27-2013 09:52 AM
yes about the IROC ; )
<table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/9uN9OrQbBZTdqtSi5Qqq3za7Oec1JUU7rLp0dWVkxfI?feat=e mbedwebsite"><img src="https://lh6.googleusercontent.com/-Xf0FO9CL6gQ/UfNpL7sX8BI/AAAAAAAACRA/PJ9-282uiLs/s800/image.jpg" height="600" width="800" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/116508652009775065996/93002?authuser=0&feat=embedwebsite">930</a></td></tr></table>
copbait73 08-27-2013 10:47 AM
Yes, it can be done but there is very little room for anything that does a really good job muffling.
Don't put an IROC bumper on a longhood or vice-versa, that is model year mixing and doesn't match well with the rockers and front bumper.
smurfbus 08-27-2013 11:42 AM
Yeah, you might be right about the over all look with mixed parts.
rswannabe 08-27-2013 01:29 PM
Smurfbus,
Is there a thread about your intercooler setup you can point me to? I would like to go without a tail on my car, but would prefer to keep an intercooler.
smurfbus 08-27-2013 08:54 PM
No thread but Chris at Turbokraft said it was an one off and NOT something they will recommend performance vise as its so thin to fit under the plain lid. But its fine for me and if I see performance loss I will connect again my water meth. I just tried 1 to 1.1bar and all went well and logs were a bit on the rich side so I will iterate until its fine in all gears and rpms.
The last change I made dipped the torque peak area under 11AFR to 10.3AFR so its a bit harsh adjustment but I hope to get a good compromise.
Here is the pic from the last owner.
https://lh6.googleusercontent.com/-L...E/s800/FB1.jpg
