Fuse wiring help
Could anyone who has a 78 or 79 930 - please take a photo of their fuse block in the truck and post. I need to see the coloring of the wires going to each fuse block.
The reason I am asking is that I received a new blade style upgraded fuse block sold here by a fellow pelicanite and just checking wiring hook-up. I don't think that the previous owner wired this correctly - I bought the car as a roller - so not sure if everything works yet. Thanks in advance for the help
08 Aston Martin Vantage V-8 (6 spd manual) (DD) 20 Cayenne white-black/red (hers) 78 930 (heavily modified) 08 GT3 RS (white/black) (modified of course) 67 911S outlaw (sold) |
anyone - I would really appreciate it.
Thank you
Picture of panel from my 2/79 build 930. Resolution should be good enough so you can cut, paste and blow-it-up a bit if needed. Hope this helps.
1979 Indishrot 930, Rudolph ------------------------------------ "Dad, buy it! Real race cars don't have sunroofs." |
Thanks - really appreciate it
Just saw this. Let me know if you need some pics from my 78
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Is that pink upside down U shaped wire bridgeing the top side of two fuses in the top left corner origonal?
The two fuel pump relays at the left end should be red relays. The black ones work and they are the same inside other than the red ones have a diode in them that blocks a voltage spike that makes life better for the electrical system and the fuel pump motors. |
Got your pm.
I will post pictures when I get a chance. My car has AC.
U shaped wire was there when I got the car a while back. Everything seems to work fine. The black relays are original for this car but I think I remember reading somewhere that the red ones might be better in certain cases. Should I think about switching out? PM me if you get a chance.
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
It is not all stock, but I hope you can use it:
