Banned
Originally Posted by Tilikum Turbo View Post
"Resale be damned"...works well if your running a negative return business or a hobby shop.
It's "you're". It's probably a good idea to use correct spelling when slinging mud.
Old 10-30-2013, 09:32 PM
Oh No !!!! The spelling Nazi strikes again !!!!!
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 10-31-2013, 07:34 AM
Banned
Ha ha, Cole, I wondered if you would see that! Obviously, my motivation here is different than when I yank your chain.
Old 10-31-2013, 08:03 AM
And I'm sure you knew I wasn't going to let that opportunity
get by me !!!!
Cole
Old 10-31-2013, 09:49 AM
clutch-monkey's Avatar
does anybody make a kit for a 3.6 turbo conversion? only found a protomotive thing for eleventybillion dollars
Old 10-31-2013, 05:51 PM
Bad LT
Uncle's Avatar
I might be able to help you out there soon Sam
Ex Porsche Cup car with some boost and stuff.
Old 10-31-2013, 06:05 PM
sweet.. i just know it's going to be all the little things that make something like this into a headache!
Old 10-31-2013, 06:38 PM
Bad LT
Uncle's Avatar
After having done it with the 3ltr and played around with set up quite a bit I'd reckon I've got quite a handle on the headache side of things.
Old 10-31-2013, 07:31 PM
TurboKraft's Avatar
What do you think it should cost?
Not being a smart*ss about it, but always curious what people think it is worth.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-01-2013, 09:42 AM
Chain fence eating turbo
Well, eleventybillion is a little high. HEHE
Old 11-01-2013, 11:13 AM
Brando
quattrorunner's Avatar
Yeah that's true, sounds like a lot to me too.
Turbo powa!
1977 911s. it's cool
Old 11-01-2013, 11:34 AM
granted it seemed to be a pretty damn *complete* kit with all the fruit and aftermarket management, but it was advertised for $9,000+ which is a bit steep for me, especially for running only 0.5bar. which seems to be doable with bolt on bits!
another mob that did it required the engine for teardown etc and it looks amazing.. but is also out of my price range
i think if i was going to go down this route i'd start scavenging parts and knock together the pipework .. i feel like the biggest cost would be the tune/aftermarket ecu?
not going to say "it doesn't seem too complex" because i know that will bite me in the ass
Old 11-01-2013, 02:49 PM
TurboKraft's Avatar
If $9k included injectors and converting to MAF or MAP, plus a name-brand turbocharger and all stainless exhaust, I'd say that's a bargain.
Can you piece it all together and build it for less yourself? Maybe, assuming you have all the fabrication equipment and free time.
If you figure your time has value, then the answer is likely no, you cannot do it for less.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 11-01-2013, 04:16 PM
i think yes- but it's the knowledge i'd be paying for in a kit i'd say, with the convenience of bolting it on in a weekend. i suspect there will be a few little pieces that would hold me up until i figure out, something they'd already have sorted in their kit. being able to buy some bits separately would be a boon!
at $9000-10,000 for bolt on parts i'm personally better off piecing it together locally over time, makes no sense to pay shipping to have them send turbo/intercooler/piping over either.
Old 11-01-2013, 07:41 PM
So, I've been giving this some thought.
Why not: MS3 + flex fuel sensor and E85? Stock compression, wastegate spring for boost on E10, blended to some peak boost when using 100% E85?
GT35 turbo, water-to-air intercooler to allow a stock rear lid.
Am I mad? I may yet find out on my C4....
Old 03-09-2014, 07:47 AM
Banned
Wish you the best of luck!!!! BTDT many times, and Chris in his 100% correct in his observations. Stef.
Old 03-09-2014, 06:26 PM
sjf911's Avatar
Isn't stock compression over 11:1?
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 03-09-2014, 06:39 PM
It is on paper, though it measures a little bit lower in reality. The beauty of the E85 is it's resistance to detonation. Plenty of people have run low boost setups on the stock compression ratio (supercharged and turbocharged).
I would think that E85, combined with closed loop knock feedback would keep things safe at around 1-1.2bar, which would more then meet my power expectations.
Old 03-10-2014, 06:35 AM
TurboKraft's Avatar
I put no faith in factory head studs. It's like they came in 2 styles: "putty" or "glass." They either stretch or break. Plenty of posts on this board documenting replacing broken studs on lightly modded 3.3L 7:1 engines.
The factory didn't get it right until the 993TT/993RS fully-threaded studs. And since those are now so expensive, it makes more sense to use ARP studs or Supertec's.
As far as running 11:1 + e85 + 1.0-1.5bar -- well, it's as one of our fabricators likes to say: "it'll work until it doesn't."
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 03-10-2014, 10:10 AM
