Stock 930 throttle body on 3.2 manifold?
Hi
Quick question, I am planning the next phase of build on my motor. I will be using a 3.2 inlet manifold and hopefully 3.2 heads. I am looking at a set of 3.2 manifolds from a seller but it does not have the throttle body. Does the stock 930 one bolt on? I have a spare 930 TB that I plan to bore out and replate but if its a custom bolt on job then I may as well go aftermarket. Thanks,
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD. |
Yes, bolts on, l also cut, rotated and welded my 3.2 intake to allow longneck intercooler to bolt on. Will have to modify throttle linkage to fit.
Ken |
