Robbbyg's Avatar
Crap *#%#@!
Im under car cleaning and i thought this is an old aircon line, as the oil lines i followed carefully and they went to the front oil cooler, this hose is sort of orange and made of cloth on the outside and my other oil lines at front of car cthat come from the oil cooler are brass, and this line/hose sort of went across under the car away from the other two, so im thinking its the aircon hose so i CUT it, so i could rip it out but oil started to run out of it.!!
So is this Not an aircon hose?
IS this an important Oil hose?
I didnt cut an oil hose did i?
did i?
The oil that dripped out of it its just some freon isnt it??
If it is the end of the world and it is an oil line Can i fix this? bypass it? how much pressure? i can not afford a whole new hose
Accepting suggestions not laughs
This is the top of the hose
continues crossways under car to the rear
here is where i cut it just under the front door area,
Old 12-31-2013, 05:25 PM
Banned
That is, as you thought, an a/c hose - the first picture shows where it connects to the evaporator which is mounted in the "smuggler's box" to the right of the access hole for the steering shaft (left portion of your picture). And yes, what came out is an oil/refrigerant mix. There are no soft oil lines that run to the front of the car (only the hard lines on the far right side), except for the short sections at the front oil cooler.
Old 12-31-2013, 05:38 PM
mark houghton's Avatar
If your intent is to get rid of all AC related things, then you're in luck! It aint no oil line, so don't sweat the small stuff.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 12-31-2013, 06:49 PM
redturbo911's Avatar
A/C line not a huge deal.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 12-31-2013, 07:31 PM
Preferred pronoun:Maestro
Norm K's Avatar
What the others guys said. You must be living clean!
When in doubt, use overwhelming force.
Old 12-31-2013, 07:32 PM
Robbbyg's Avatar
PHEW !
The 930 gods must be smiling
Old 12-31-2013, 08:21 PM
