-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Help with leak down numbers (http://forums.pelicanparts.com/showthread.php?t=798308)
930lover 02-24-2014 01:59 PM
Hello, fellow 930 owners. I love my 930 very much but as time goes on I wonder if my future involves expenditures other than a vintage Porsche. I recently had some minor work done on the car and had my mechanic do a compression and leak down test. these are the numbers and I am wondering if these are good numbers.
CYL 1, 115 PSI, 3% LEAKAGE
CYL 2, 110 PSI, 5% LEAKAGE
CYL 3, 115 PSI, 3% LEAKAGE
CYL 4, 115 PSI, 3% LEAKAGE
CYL 5, 115 PSI, 3% LEAKAGE
CYL 6, 110 PSI, 4% LEAKAGE
Any thoughts?
Tom G
JJ 911SC 02-24-2014 02:43 PM
While the PSI are "low" (normally around 160 for a 3.2 NA), there is less than 5% differential between the high and low which is good.
This may be due to the way it was done (time on, temperature, gauge and so on).
As for the leak down, they are pretty good.
I'm sure that some Turbo expert will chime in.
Ronnie's.930 02-24-2014 02:50 PM
Leakage( 5% and under) and compression (110-120) numbers for a turbo engine with a 7:1 static compression ratio are excellent.
JJ 911SC 02-24-2014 02:54 PM
He can now relax...
T77911S 02-24-2014 04:03 PM
looks good. how many miles
Tt surgeon 02-24-2014 04:19 PM
Great numbers
930lover 02-24-2014 08:58 PM
Thanks very much for your input. 77,000 miles on the odo. I feel better.
