Is very busy
So I was about to drive to Plano for Cars and Coffee this morning, and I notice the turn signal and taillight on the driver's side are not working when I had my headlights on. The turn signal and taillight do light up however when I apply the brakes or use the turn signals, but they don't stay lighted when my headlights are on. How can I easily fix this myself?
Thanks,
Jason 1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser 1986 944 Turbo (951), 350+hp, Guards Red- Track car 2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver |
Tinkering Pays!!
It might just be a bad connection from the car to the bulb. I know i've had to go in [with the battery disconnected] and pry the little copper prong outward with a thin and long screwdriver from time to time. Seems to solve my problem for a bit...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
no.
dont remember if its the left or right, but there is a diode in the circuit for one side. as an electronics tech i dont know why. mine did something very similar. would work one way but not the other. anyway, the diode is right under the dash. i removed mine and checked it and it was fine. put it back in and all is good. perhaps just a bad connection.
Is very busy
the diode is right under the dash. pull it down and just remove all the connections and connect it back and see if that fixes it.
had this problem and it was two things That I found with my power probe.. pinched wire pass. side him\nge of the decklid and bare wire on the decklid light where it enters the fixture
Is very busy
Okay, I'll probably try doing that. I rarely drive my Slant at night, and it's usually on my way to Cars and Coffee early in the morning, so I'm really in any hurry to do that fix.
