Help me get my car sorted after accident repair
Well, my car is back in the garage after almost 11 months in the shop.
This has been a long struggle and the car is not yet back to its prior state. There a apparently lots of issues either not addressed or improperly addressed. I.e. The WUR vent line was hooked up to the BOV signal line. I hope it did not rupture the diaphragm. The car is running richer than I remember, could this be it? Also, the rear engine to chassis rubber seal does not seal properly. It is if is the tin sits too high in the lh side. Can I just use a jack under the engine and remove the engine mount bolts and lower it down to re situate the seal? I will continue to post questions to these small issues since it has been almost a year since I've worked on this car.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Metal Guru
Loosen the bolts where the console attaches to cross beam, level the powertrain and re-torque those bolts.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
