Azzurro
Sway Bars
Now that I have good rubber on the car I am going to change out the sway bars. Any recommendations?
Old 06-12-2014, 11:41 AM
proffighter's Avatar
Tarrett over Weltmeister for sure
Roland
930 Turbo '81 Too many modifications to list
Old 06-12-2014, 01:50 PM
full quack's Avatar
Send a message via Yahoo to full quack
+1 for Tarrett.
Mark
Old 06-12-2014, 05:31 PM
Tilikum Turbo's Avatar
Unless you track your car, just note your ride quality in the street will suffer the stiffer your sway bars.
The streets in Los Angeles ar khrap.
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 06-12-2014, 05:54 PM
gumba's Avatar
"Unless you track your car, just note your ride quality in the street will suffer the stiffer your sway bars."
Not really. Sway bars only work when going through the corners. What kills the ride quality is big torsion bars/ high springs rates, heavy duty, or race shocks, monoball camber plates, etc.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 06-12-2014, 06:29 PM
I have to dissagree, swaybars does affect riding quality as they connect LH suspension with RH suspension and that has influence to the indipendend wheel suspesion, if one wheel is hit, the other will be moved a bit as well. No more floating as all single acting.
Roland
Old 06-13-2014, 02:50 AM
gumba's Avatar
Splitting hairs. Yes, if you used a massive sway bar and hit a big pot hole, but that would be the least of your worries. If your going down a crappy road everything I mentioned above would have much more impact on the ride quality. If your going down the same straight crappy road with the sway bar disconnected I doubt you could tell.
A nice street up is harder to achieve because you would need to take into considerations the road quality you most drive, and what your willing to tolerate. It all gets down to personal preferences.
Harold
Old 06-13-2014, 05:53 AM
Rear monoballs smooth out the ride in back noticably because they remove the sticktion of the original rubber trailing arm bushings that are bonded in place on the inner and outer diameters and have to twist for the trailing arms to pivot.
Old 06-13-2014, 06:38 AM
gumba's Avatar
Nobody has commented on the negative side of sways.
Harold
Old 06-13-2014, 07:05 AM
BlkBird's Avatar
TRG's front and rear are what I am running.
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 06-13-2014, 07:58 AM
gavinc69's Avatar
I'm running TRG sway bars front and rear, there set on middle adjustment and they definably effected the ride quality. Its stiffer feeling and a bit fidgety.
They are the thickest bars they did mind you, massive over kill for the road but man does the car stay flat in the bends
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 06-13-2014, 11:02 AM
TurboKraft's Avatar
Smart Racing Products. Great quality, highly adjustable, rear links put in the right spot on the spring plates.
+1 on rear spring plates.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 06-13-2014, 12:35 PM
Bland
unclebilly's Avatar
I run Weltmeisters on my track car. They are fine and allow for infinite adjustablilty. It has 23mm torsion bars up front and 29s in the back.
Old 06-13-2014, 01:55 PM
Azzurro
Sway Bars
Wow! Lots of options. Thanks everyone.
Old 06-16-2014, 07:15 AM
