Hi does anyone make a custom engine mount crossbar for 911 turbo .. im after something a little more hi-tech looking..
Turbo Hooligan
D-Zug ![]() |
Pelican Parts Vendor
As OldSpool linked we have a really nice stainless piece if you're interested I'd be more than happy to answer any questions or get one out the door for you!
Shawn@Rennline.com |
IMO, the Rennline part is too flexible. Nice that it's stainless, but too flimsy for my comfort. (Sorry guys, we do like just about everything else you make.)
The D-Zug one is retro race cool! Does it allow you to keep the stock engine tins, maybe with minor trimming/modifying? FWIW, the stock part is easily modified to be sturdier at the ends by welding in thick gussets, and lightened by using a hole saw and dimple die. ![]()
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft Last edited by TurboKraft; 08-15-2014 at 11:59 AM.. Reason: edit |
If you look at our brace it is effectively strengthened on the top and bottom by 90* gussets running lengthwise in addition to really heavy gussets where you've showed some welded in. Plus without being welded on nearly as much as modifying a stock piece you aren't introducing the brittleness that can come with heat cycling, especially on a 25+ year old part, and we use stainless throughout meaning you aren't welding estranged metals together. Between the superior material, thick plate and gussets on the end "flexible" isn't a term that comes to mind! |
Hi Shawn, looking on your website, I see Rennline has updated the design.
The prior generation version, as customers have brought to us to include on their builds, is shown in the top photo (http://www.rennline.com/images/m01s-rs.jpg). It only had the gusset along the top, and the threaded ends had the single weld bead. I see now you've updated the design with the lengthwise gussets top & bottom, and boxed in the ends. Glad to see the revision, that's sure to make the part considerably more rigid in all 3 axes. Thanks for bringing that to my attention, we'll try them again.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Yes we revised the design a while ago for that exact reason, you're right that the old setup was more flexible. This is definitely a much more beefy design, I'm glad you like the new unit better!
Kartoffelkopf
Here's my modification to a stock brace, total cost about £10 including re-powder coating it. Not that exotic...in fact, not exotic at all!....but looks stock-ish, which is the "factory sympathetic" look I'm trying to kind of achieve with my build.
![]() But....I do rather like the Rennline one. Damnit guys, stop posting engine pr0n, I'm trying to finish my build, not look at ways to spend even more money!!!!
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
Sorry?
I like your modifications too, you must have a nice powder coat guy to have got all that done for £10, kudos! |
That looks like an older one that has no female threads on the inside. I may be wrong though.
The later ones with female threads inside don't need a lock nut on the bottom and are sooo much easier to use. Antiseize or grease on the bolt will keep it from possibly rusting into the stock ones. |
Kartoffelkopf
Hahaha!
All 964/993 cars have studs protruding down from their engine mounts, and thus use a shouldered nut underneath the crossbar. 996/986, too, same mounts.
Kartoffelkopf
Ahh ok thanks for clarification Chris....was confused to there being reference to an "early one", as mine's a late MY1992/registered '93 Gen 964, so the later end of 964 production.
