Ingenieur
Slow fuel fill
Do all model year turbos have a slow fuel fill (nozzle shuts off when filling)? Is there a restriction of some kind in there?
Old 08-04-2014, 07:16 AM
Turn the nozzle 180* when inserting. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 08-04-2014, 07:55 AM
porche's Avatar
With some nozzles you may still need to regulate the fuel flow by hand at less than full. The automatic fill feature may or may not work all the time.
1979 Indishrot 930, Rudolph
"Dad, buy it! Real race cars don't have sunroofs."
Old 08-04-2014, 09:40 AM
Ingenieur
Thanks. I too have discovered the workarounds. I was wondering if anybody had figured out the root cause of this annoying behavior.
Old 08-04-2014, 12:27 PM
porche's Avatar
Thought I read somewhere it had to do with the angle of the pipe to the tank. It is pretty flat in the area under the fuse box on our cars.
Old 08-04-2014, 02:36 PM
I've gone native
Tt surgeon's Avatar
Great tip!
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 08-04-2014, 04:25 PM
Roby466's Avatar
The 911sc I use to have had the same problem, my current 930 has a pin a few inches in the pipe that prevents the nozzle from being fully inserted (causes a bit of spraying out of the pipe as well). It was probably there to prevent a suction hose from being inserted. While the 930 (with the pin) still does it from time to time, the 911sc (without the pin) would allow the nozzle to be inserted fully and would trigger the stop constantly. Might have something to do with that pin. My 930 is a grey market, do US cars have the pin as well?
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 08-08-2014, 03:40 AM
Dai Dai is offline
My 81 930 Canadian car has one of the pin as stated above and it does prevent the nozzle to be fully inserted. It works great except you have to watch toward the end that you don't over filled.
1981 black 930 with full 1st gen Gemballa bumpers kit. RUF classic wheels. Modification include: Mode Inc. (Bob Holcombe) full bay intercooler, headers, turbo, and muffler. 360RWHP.
Old 08-08-2014, 08:09 AM
The 180 trick doesn't always seem to work for me so I just regulate by hand and pump a little slower. I can usually pump at 50-75% of full flow. Happens both on my 930 and my 993TT FWIW so the filler neck design must not have changed much across different generations of air-cooled turbos (and other 911s).
'72 911 ST Tribute (built by Scott Longballa) - Signal Yellow
'74 911 Carrera Targa (2.7 MFI - RoW) - Silver / Polaroid Stripes
'77 930 - Minerva Blue
'97 993 Turbo S - Ocean Blue Metallic
'13 981 Boxster (BGB 3.8L 991S conversion) - Racing Yellow
Old 08-09-2014, 06:01 AM
Metal Guru
911nut's Avatar
Inadequate venting due to a restriction in the vent line or evap system is usually the cause of nuisance premature shut-offs. If the air in the fuel tank is venting through the filler instead of the vent valve(s) or vent line, fuel wells up in the filler neck and triggers the nozzle to shut off.
The fuel tank in my car has only one vent valve. It probably needed two.
My '81 SC had the same issue. I guess customers didn't complain enough about it.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 08-09-2014, 12:26 PM
speednme1's Avatar
That sounds about right...one way I've found to avoid the issue is to stop topping off during fuel fills. Trying to squeeze that little extra in seems to have a negative effect when refilling comes around. Funny thing is my daily does the same thing..I've stopped topping off and it seems to alleviate the issue.
Rey....77 930 "the Mistress"
Old 08-09-2014, 01:13 PM
Metal Guru
911nut's Avatar
Nozzle shut-off when topping off is by design. When the filler neck fills with fuel (which happens when the vent tube in the fuel tank is submerged; it will stop venting the tank at this point), it will shut off the dispensing when the fuel wells up to the nozzle. The rule for newer cars is 2-3 clicks. Any more and it will end up in your shoes or, God forbid, in the charcoal canister (necessitating a new canister) in extreme cases.
Paul B.
'91 964 3.3 Turbo
Old 08-09-2014, 03:41 PM
