Cam recommendation for 3.4 EFI
Considering a cam change for my 3.4 twin plug efi motor. Currently has SC+ cams. Looking for strong low end response and would sacrifice top end as it will not be tracked. Will be going to a GT35R turbo to get things spooling sooner. Suggestions for a grind profile? Would especially like to hear from Chris Carroll. Thanks.
73 914-6 GT tribute, 2.7L twin plug 23 911 w/aero kit 07 GT3 RS Pumpkin |
Kartoffelkopf
Hi, I'm running (...or will be running) 964 N/A cams in my 965 EFI project, also 3.4 with twin plugs. Like you, it's not a track car so I decided against GT2 cams, from what I read, they're just a little too hairy for what I wanted. I'm working with Chris @TurboKraft too, I know he also has his design of profile and if I knew 3yrs ago that the project would be this long, I'd have bought these, but at the time a pal of mine happened to be selling a very nice pair
The first few pages of my thread (below) has commentary from Chris that you may find useful S ETA my signature....original post was from phone
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject Last edited by Spenny_b; 10-10-2014 at 08:47 AM.. |
E-85 sippin drunk
Subscribing!!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
3 restos WIP = psycho
What's your compression ratio?
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
I went with Dougherty DC13 cams. I recently finished my rebuild and conversion to EFI. I am also running a Garret GSX 61 Ball Bearing Turbo. The DC13 cams give you the best of both worlds. SC low end grunt and 964 top end. Spool is almost instantaneous, and the car pulls all the way to red line.
I would highly recommend them.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. |
I think of installing cams 993SS, they are one of apparently better compromises for our engines 3.4L and even 3.5L. Dougherty can supply them, I have a friend who was able to order it to him in 2013.
Once you're on boost, it all changes, of course. Based on my calcs, at-idle static CR (on book timed) 993SS cams is even lower than for GT2 cams, meaning you can expect lazy performance off idle. Advancing the timing will net you a little more dynamic compression at idle, but you still shouldn't expect anything better than somewhere between 964 and GT2 performance off the line. The OP stated he wants more off the line grunt at the expense of top end power. 993SS cams are not the solution for his problem. From his initial post, it sounds like he is running DC15 cams, which although nice, will give up a little off idle grunt compared to an SC cam. In reality, the OP is probably best off emailing with John Dougherty to get a custom ground cam - ideally something with near stock overlap to maximize off-idle compression, with a little more lift dialed in to allow a little more top end power than the stock cams. A DC 10/12/13 may be a good option in this pursuit. FWIW, my CIS 8.5:1 CR, 3.4L motor is now coming together with 993SS cams, K27-7006, 40I/38E ports, knock control and twin plugs. Knock control means I'll be able to run a sharper advance curve which should mitigate some of the off idle laziness. Cams will be timed w/ 4 degrees of advance. I'd of course be best served with fast spooling ball bearing turbo, but budget isn't accommodating right now. I'll let you guys know what they are like once I do.
Hi,
If ever you need an answer more quickly, PM me and I'll get a popup email notice. 8-) You have EFI, so you're not limited to little bitty CIS-friendly cams. You already have SC cams, going to a DC13 would hardly be a big step up. 964 -- great all-around, but there's room to go, especially if you want more torque and are willing to forego a little peak power to get that punch. Look at my recent post about swapping out factory SC cams for some bigger TK EFI-T camshafts in a 7.5:1 3.4L EFI 930 with a GT35R : http://forums.pelicanparts.com/8269836-post179.html Huge torque gain by 3,000rpm, power until 6,000rpm with a flat manifold. They would be a drop in replacement on your engine. FWIW, we've done 600rwhp on a 3.5L stroker with these same cams, flat 930 manifold. Fun even with CIS injection -- used in Black_Hat's C2T: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/767012-forced-deal.html And if you want the all-out-best-of ground camshafts, TurboKraft has partnered with Edelweiss Motorsport and offers their camshafts. Dirk's profiles include all the latest tech in the camshaft's lobe design for optimal performance and durability. Prices are comparable to new factory Motorsport camshafts, and equal in quality.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
^ Dirk is a bad ass.
993Ss cams
I run these cams, and do not find them laggy at all. Lots of wheel spin in 1st/2nd gear.
![]() . Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Thanks Chris, I will be contacting you.
It is strange, in a conversation with my friend, Dougherty told him that of the good about acc 993ss. Compared with those of Gt2/ Gt2evo they are better in the bottom and at the middle regime and then our power is not situated in 7500tr / mn. I would be very curious to have more precision about acc Edelweiss Motorsport, I found nothing on their Web site.
