Turbofrog
Identify my flywheel
This is the setup I have. I'd like to replace the friction plate on the flywheel if it's possible. Its about 18mm thick and came with the conversion kit for early 930 clutch PP.
The fw only has p4-1168 carved on it! ![]() ![]() The PP has a groove for the starter ring and tb is the long one.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
Looks like a Findanza wheel. They produced an aluminum flywheel with the steel friction plate riveted in that manner.
Fidanza Aluminum Flywheels
RGruppe #180 So many cars.. so little time!! |
Turbofrog
If it is I have one spare friction plate from my Audi LWFW to use. That would be a nice surprise. I need to check if the size and bolt holes match up.
