Blinker is Blinking 5X per Second?
Recently, my left and right blinker have begun to blink at a very high rate [including the hazards]. I notice all of my bulbs are working, but the blinking is at high rate.
It seems this happened in the past and was due to a bulb not being in good contact in the socket. That all seems fine, now... Should I be looking at the blinker relay? Grounding Issue? Thanks guys! |
Once all contacts and bulbs are good with clean contacts, the flasher could be dying.
It's behind the brake booster IIRC. |
i'll look at the p/n of the flasher and get another. thanks!
Bad light bulb/contact.
I'm now thinking it may have to do with the LED's in installed some months back. The quick flashing wasn't a problem back then, but now it is...
I purchased a specialized relay for LED installs. I'll post back when I get it installed. Thanks! |
^^^oh, well...
I installed an LED relay and everything works perfectly, now.
Sent from my iPhone using Tapatalk. |
| All times are GMT -8. The time now is 08:06 AM. |
