Replacing a Turbo
I have an 1988 911 with a bad turbo. Would you please direct me regarding instructions on how to replace this?
Old 09-26-2014, 03:39 AM
T77911S's Avatar
remove the muffler
remove the turbo
i take my bumper off. one of the muffler bolts may be VERY hard to get to. i have also made it easier to take my bumper off.
there are 2 oil lines and 4 bolts on the turbo.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-26-2014, 04:03 AM
totle's Avatar
As desrcribed.
You need to remove rear bumper to get easy access.
Remove intercooler and downpipe.
You will have to remove oil drip tank and oil feeder line in top of turbo cartridge.
remove the exhaust and bracket.
The turbo is held by 4 bolts on the T3 flange of the exhaust.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 09-26-2014, 04:24 AM
Crotchety Old Bastard
RarlyL8's Avatar
I do not remove the rear bumper to R&R a turbo.
> Remove valance and heat shield.
> Remove muffler.
> Remove intercooler.
> Unbolt upper and lower oil line.
> Loosen turbo bracket bolts.
> Remove oil catch can.
> Remove turbo and bracket.
> Installation is opposite of removal. Be sure to prime the turbo.
Old 09-26-2014, 04:55 AM
PorscheMoparLiterbike
b5aar's Avatar
Personal preference with the bumper.
For me just easier to access top oil feed and tighten bolts/nuts properly. also usually start it up with bumper off to check for leaks other issues.
88 930 BnB Kinesis tial 1bar k27/29, Turbokraft IC+blocks+rokr loks+ ported intake,edelweiss cams, KEP/Sachs, Verden Tool 38mm PP heads, ARP bolts/studs, twin plug for future
Old 09-26-2014, 07:11 AM
oilonly's Avatar
If you have a lift no need to remove bumper just valance and heat shield. If doing it on the ground remove bumper so you don't have to work on your back the whole time like a younger you. Be careful lots of debris in there that will fall in your eyes. I removed the bumper so I could clean everything nicely while doing the job.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 09-26-2014, 08:04 AM
mark houghton's Avatar
+1, but age is relative to the condition of your body. 61 in another couple of months and I will be laboring away at yanking out a crispy BBQ'd drive train. Probably be crippled by then or a bad case of COPD from inhaling all the soot $hitt.
We're talking like 6 or 8 screws to remove the valence and gain all the access a person needs.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 09-26-2014, 05:58 PM
I always take the bumper off with the valance and tag on it. It's very quick and easy to do and the ugly USA bumperettes are long gone on mine so that makes it easier.
I have different license plate lights and I put spade terminals on my home made wire harness behind the bumper for them.
You can sit on the ground behind the car and reach everything easily when there's no bumper on the car.
Old 09-26-2014, 08:28 PM
Mr. Gimpy, your 61 !!!
I've got shoes in my closet older than that.
I'm 71 and just pulled and replaced a turbo a week ago.
This week I've been hanging 93 feet on new gutter and 7
14 foot down spouts. Still have 210 feet of roof heat tape
to install and wire before the cold weather gets here.
Great to see your back !!!!! Hope your loving the new 930
and we have all missed your sick humor, Don't be a stranger.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 09-26-2014, 10:02 PM
Cole
Dammit Cole, I had a mouthfull of Shiraz and laughed it all over my 'puter screen. Shoes that old have got dry rot by now, all curled up at the toes like Munchkin shoes. Besides, nobody wears Oxfords or Wingtips any more.
Like I said, age is relative. Apparently you haven't aged one bit!
Old 09-27-2014, 05:54 PM
