Just did rear wheel bearings and have?
I torqued the hub to 145 but I feel like there is resistance when I turned the hub no rubbing just resistance is quite hard to turn is that normal?
Thanks Erick
Old 10-01-2014, 09:18 AM
EmptyGarage's Avatar
I had my own issues with this. I read the installation procedure as torque to 145 then back-off and re-torque to ??. Can't recall the second and final torque value but was in the OEM maintenance manual
1986 930 EFI, twin plug, lovin the sport seats
Old 10-01-2014, 09:46 AM
Hi guys
Once I put the dial indicator on the face of the hub, how do I measure the axial play.
Do I pry the hub with 2 screwdrivers one on each side with some force ?
If I do it that way I get 20/100 mm play ,if I do it by hand I get 5/100
Thanks for your help
Erick
Old 10-01-2014, 09:31 PM
Turbofrog
smurfbus's Avatar
On the manual they show one screwdriver used in between the air fins on the rotor.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 10-01-2014, 10:10 PM
