-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Turbo 4 speed to G50 (http://forums.pelicanparts.com/showthread.php?t=841991)
porsche 930twin 12-08-2014 08:36 PM
Hi all I am trying to get measurments or a diagram on machining G50 bellhousing and input shaft to fit it into a 1981 930 turbo I do not want to cut the torque tube... does anyone have a diagram...
Mario Motta 12-08-2014 09:39 PM
I did on my 78'. Everything will fit. I will send you some picture when back home. I installed removable gearbox mount, spacers on the torsion bar and i made more space under the gearstick (less than an inch) to fit the g50 gearstick from carrera 89'. At the end the only modification i did on the car was this little box i made under the gearstick. I will check how much i cutted from bell housing.
porsche 930twin 12-16-2014 01:37 PM
Hi Mario did you find the pictures and measurments to install G50 into turbo 4 speed...
lite75 12-16-2014 01:46 PM
29mm max
porsche 930twin 12-16-2014 03:35 PM
Hi Lite 75.. is this of both bellhousing and input shaft are there any diagrams or pictures that would show the total swap...
lite75 12-16-2014 09:29 PM
yes, both. 28mm should do it for you unless its a 75-77.
JakobM 12-17-2014 06:39 PM
what if 75-77 ?
lite75 12-18-2014 07:41 PM
They will need additional room, either move the motor back or notch the torsion tube. 75-77 have the motor mounted further forward compared to the later models.
Matt Monson 12-18-2014 09:28 PM
This is accurate. We usually say 1.1mm. That's how much our 3 piece mainshafts are shortened.
Regards,
Matt
quattrorunner 12-18-2014 09:35 PM
You mean 1.1"?
Matt Monson 12-19-2014 07:19 AM
You mean 1.1"?
Yeah...that.
JakobM 12-19-2014 10:13 AM
Thanks, I know the engine is mounted 2.5mm (as I am informed) closer to the center of car compared to a 78-89, what I ment was, do we have knowledge to the additional measurements that has to be removed on the shaft, housing etc. to fit a 75-77 OE mounting?
I was under the impression that a G50 bellhousing could be set up and shortened to fit a 75-77 without having the engine moved 2.5mm backwards
