1 bar spring and adjustable wur
Hello,
I've installed a 1 bar spring and the afr was 10:1 i adjusted the wur to get 12 :1 under boost and now the pressure switch cut off my fuel pump. Can you explain this?
Old 04-25-2015, 02:55 AM
klefroid's Avatar
https://depfile.com/CgSefLSVqk
download manual and look for page 87
it is possible that the overboost sensor may be your problem ... when does this happen and how?
Old 04-25-2015, 05:03 AM
Crotchety Old Bastard
RarlyL8's Avatar
The pressure switch cuts off at 1.1bar, if you are experiencing overboost then the switch would activate. Overboost is a very common by product of many aftrermarket exhaust systems due to changes in pressure differential and poorly designed waste gate plumbing. Defeat the switch and see where your boost level is. Obviously be ready to get off the throttle if it goes to the moon.
Old 04-25-2015, 07:38 AM
Non User
infraredcalvin's Avatar
The more I cleaned up my plumbing (new seals and gaskets) the more issue I had with boost spike. I put some shorty headers and one of rarly's mufflers and she's a different car, but I see 1.1 to 1.2 boost spikes in all gears. I'm considering going back to the inefficient OE HEs to see if it eliminates the problem... For now...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 04-25-2015, 08:03 AM
oilonly's Avatar
When I went short tube headers my boost came on too high also, put in an .8 spring in waste gate to solve problem think a .7 would be perfect. That will get you 1 bar at the gauge/in engine. Stock exhaust uses the waste gate better than short tube headers. Brian's system puts the waste gate in a serious position also.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 04-25-2015, 08:30 AM
My car has dansk headers now i've installed the 0.8 bar spring and the problem is gone. I did'nt know that the pressure switch closes at 1.1 i thought it was 1.2 or 1.3. So with the original spring i might be already close to 1 bar correct? When the switch closed i was almost out of the windshield😄😄
Old 04-25-2015, 10:45 AM
oilonly's Avatar
Correct Mario.
Old 04-25-2015, 11:27 AM
