jbrown's Avatar
EFI guys
What are you doing with your blow off valve. Are you venting back to the intercooler or to atmosphere? Also are you using the stock bosch plastic one or is there a better choice.
I was told the bosch is a little small...
Thanks John
83 sc cab turbo widebody. 3.5 liter supertec motor, B&B headers, EFI electromotive TecGT, TurboKraft GT35R billet turbo, 964 cams, WM inj, Bell full bay intercooler, Short bell housing turbo 4 speed tranny, roll bar, hargett shifter,
Old 03-26-2015, 11:00 AM
John, I have done both, vented back to filtered intake air, and now, vented to atmosphere. No difference in performance, not even a change in sound I run the stock 965 black plastic valve, which works just fine. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 03-26-2015, 11:28 AM
dos531's Avatar
If your system is running speed density then there is no reason to recirculate it.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 03-26-2015, 11:30 AM
E-85 sippin drunk
turbobrat930's Avatar
I think I have the "Q" series of BOV's from TiAL. It is right above my turbo outlet, and just before the inlet of the I/C. It vents to the atmosphere.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-26-2015, 12:36 PM
jbrown's Avatar
I was told that I can vent to atmosphere. Right now I have it recirculating. If there is no difference I would like to leave it. If it makes a difference or is recommended to vent to atmosphere .
Thanks John
Old 03-26-2015, 01:47 PM
Chain fence eating turbo
Psssssshhhhhhhh
Old 03-26-2015, 02:30 PM
dos531's Avatar
Thanks John
I cant imagine it would hurt anything to recirculate it, but its just extra plumbing.
Ducati 748R
Old 03-26-2015, 02:37 PM
jbrown's Avatar
Is your car EFI? If so I was curious if you are using the meth injection and where you have it plumbed in.
I have meth injection and the jet is in the out pipe of the intercooler. I am bringing it to the dyno Monday and I was wondering if it would interfere with the temp sensor, which is only about 8" away from the meth jet. I would like to keep the system in. It cools the charged air and worked great with the CIS system.
Old 03-26-2015, 03:20 PM
jbrown's Avatar
I should have read the bottom of your reply. It shows BL WUR, so you are still CIS.
Old 03-26-2015, 03:21 PM
dos531's Avatar
Yep still cis for a short time longer. Currently still assembling my EFI hardware. I have been researching the same question to determine where I will be installing my IAT sensor in relation to the methanol jet. I have not found a definitive answer to whether it should be installed before or after the meth jet. I'm leaning towards installing it after the jet, but out of the direct spray of the methanol. That way its reading should take into account the cooling effect of the methanol. If I remember correctly your iat was installed in the Cold start valve location? If so, that is what I am planning to do as well, but with a spacer to insulate the sensor from heat soak as well as hopefully keep it from being sprayed directly with liquid.
Hopefully someone with more knowledge can chime in regarding the iat/meth jet orientation.
Ducati 748R
Old 03-26-2015, 03:32 PM
If the nozzle is far enough upstream to not freeze the IAT, I think it would be fine. Meaning, I wouldn't have the IAT directly sprayed or it'll think the actual air temp is extremely cold and go pig rich.
Old 03-26-2015, 05:42 PM
xbmwguy's Avatar
Dump to atmosphere. And plumb it as close to the tv ass possible, so when the tb blade slams shut you still maintain some in all plumbing.
Old 03-27-2015, 09:45 AM
Banned
FRANK! (always plumbing "it" close to the "tv ass", you are!)
8-)
Old 03-27-2015, 11:24 AM
Turbo Hooligan
BOV's aren't necessary. But we typically vent to atmosphere when they're used.
D-Zug
Old 03-27-2015, 11:59 AM
Really?!?! I prefer not to crash my wheels back in forth in the CHRA!
Old 03-27-2015, 12:17 PM
jbrown's Avatar
I already have it set up to vent back into intercooler. If there are any performance gains or the car runs better dump to atmosphere then I will chance it but if there is no difference except for sound I prefer to keep it the way it is. Thanks John
Old 03-27-2015, 04:46 PM
dos531's Avatar
It actually vents FROM the intercooler and is recirculated into the intake before the turbo. The 964 bypass valve does look like kind of backwards like that though. On mine it is just a bov mounted on a flange on the back of the intercooler.
Ducati 748R
Old 03-27-2015, 05:41 PM
xbmwguy's Avatar
Pete is correct. Most modern turbos are made with anti surge ports
Old 03-27-2015, 05:52 PM
Yeah, modern turbos, but most here are in the K27 camp.
Old 03-27-2015, 06:24 PM
xbmwguy's Avatar
Sorry to hear about their bad luck
Old 03-27-2015, 07:34 PM
