puddy's Avatar
Replacement hoses
What are you guys using for replacement intake hoses. I'm looking to replace many of my rubber intake hoses on my 930 motor, some are 3/4" and 1" diameter. What do I ask for at a parts store, would it be considered vacuum hose? I put some silicone hose in front of my auxillary air bypass valve and it collapses so I need something that won't collapse. And I can't use factory hose because of my large intercooler things aren't exactly where they usually are on a 930 motor.
Thanks!
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 04-13-2015, 04:59 AM
I would check with our host first to see if they sell it by the foot or meter. If they don't I know Kurt at PartsKlassic has the hoses. He has a 930 himself and is very knowledgeable.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 04-13-2015, 05:02 AM
puddy's Avatar
OK, thanks, I see Pelican has vacuum hose 12 x 19mm and 14 x 19mm, I assume 19mm is the diameter, what does the 12 or 14 represent?
Cheers, Chris
1986 951
Old 04-13-2015, 05:44 AM
