-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Intercooler seal question (http://forums.pelicanparts.com/showthread.php?t=862822)
ertech 04-28-2015 05:07 AM
Hi guys what are you using as an intercooler seal for the Andial I/C
Norm K 04-28-2015 08:28 AM
Where are you having problems? Is this a short or long neck I/C?
With new (or at least serviceable) o-rings a short neck should seal up nicely at the I/C itself. The problem is often (or at least sometimes) getting a good seal where the charge pipe connects with the turbo. This is pretty easily remedied by cutting off the bottom of the charge pipe (the flared area into which the o-rings are supposed to seat/seal) and using a 4"-5" length of 2" silicone hose and high quality clamps. No more leaks.
ertech 04-28-2015 10:12 AM
Sorry my English is not yo good
I was talking of the seal on top that goes around
kenikh 04-28-2015 02:03 PM
I'm facing a similar question - this is related to the gasket between the IC and the decklid grill. I was thinking I'd fabricate something out of an off the shelf extrusion.
