Two spare 38mm injector blocks anyone?
While I was cleaning my disassembly parts bin I found out two of my injector blocks are badly warped. I would like to drive this summer with the good old CIS and for next year switch to EFI. I Zdont think I could get the running as a EFI already this summer!
So let me know if you have couple of straight 38mm ones available. I have modded alublocks but those a for EFI injectors so I cant use them at this moment. I just checked my dry install and there is more than 3mm valve piston clearance so the rpms must have skyrocketed to get piston-valve contact and brake the cyl6 exh rocker last sping. |
This is number 6 witch had closed exhaust valve for a while so it banged on the intake manifold
http://forums.pelicanparts.com/uploa...1430233228.jpg |
| All times are GMT -8. The time now is 12:46 PM. |
