Porsche Crest Fuel pumps Big HP
Hi all just wondering what fuel pumps, filters,..pressure regulators etc etc people are using for higher horsepower engines... Are surge tanks necessary
photos would be great..
Old 05-19-2015, 04:46 PM
IMR-Merlin's Avatar
CIS or EFI?
Old 05-19-2015, 04:49 PM
Registered turbo addict
Menmojo's Avatar
I run an aeromotive A1000 with EFI.
That's on a 930 that has run 700+HP at the wheels on a dyno jet.
Great fuel pump with no issues.
It's able to keep consistent fuel pressure of 42 PSI under all conditions.
A1000 Fuel Pump - Aeromotive
Old 05-19-2015, 05:27 PM
xbmwguy's Avatar
+1 on A1000
Old 05-19-2015, 05:46 PM
fuel pump
Thanks for the reply do you run pre-filter before pump and what pressure regulator do you run.. this is for a EFI motor
Old 05-19-2015, 05:58 PM
Menmojo's Avatar
I have the A1000 mounted on the floor of the front trunk next to the fuel cell.
I can't remember the brand of the regulator and I'm not using a surge tank.
I hope this helps......
Old 05-19-2015, 07:48 PM
E-85 sippin drunk
turbobrat930's Avatar
I am running dual 044 Bosch motorsports pumps, and an Aeromotive FPR. Thats on a EFI 930. Rock steady 50 PSI
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 05-20-2015, 04:02 AM
xbmwguy's Avatar
Brad will find out soon enough when he starts running e85 about the 044s and longevity
Old 05-20-2015, 01:19 PM
Chain fence eating turbo
I've ran an Aeromotive on a different car and twin 044's. These are both plenty for big hp.
Old 05-21-2015, 06:54 AM
Kartoffelkopf
Spenny_b's Avatar
Running twin Bosch 044's and a Fuelabs FPR; EFI 544fwhp/514lbft as measured on an engine dyno.
ETA - stock 964 in-tank filter before the first pump, then stock 965 filter after second pump and before the injection rail
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 05-21-2015, 10:12 AM
xbmwguy's Avatar
Here is my 2 on twin pumps Efi and big boost/ power. If and when you are boosting big and one pump fails you just went lean big time. If your single takes a crap you shut down. I know there are safeguards one can take in the programming but .....
Old 05-21-2015, 10:58 AM
That is a very good point. Better to have to call a flatbed than call Mahle.
Old 05-21-2015, 12:42 PM
fuel pumps
Thanks for the input guys ...do these all fit in the standard location or does they have to be relocated... any need for a surge tank.. picks pics...
Old 05-21-2015, 01:21 PM
Porsche race cars always had at least two fuel pumps in parallel. They would run with only one fuel pump but they had 2 or 3 in parallel so if one failed during an endurance or sprint race the car could still finish.
Old 05-21-2015, 01:30 PM
