EGT x6 @ air injection ports?
Is it possible to use the air injection ports to retain EGT probes? Seems like it would be a convient place to put them. Then tune CIS unit so EGT matches at each.... Has anyone done this yet.
Old 05-16-2015, 06:05 AM
3 restos WIP = psycho
kenikh's Avatar
I've wondered this...
Have you measured the diameter and thread pitch of the air injector port? From there, it is just a matter of finding a compatible EGT sensor.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-16-2015, 06:26 AM
Interesting idea. Does CIS allow for tuning at the cylinder level though?
Curious how it turns out.
Old 05-16-2015, 07:20 AM
kenikh's Avatar
^ it can be done
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-16-2015, 07:51 AM
They're 10mm x 1mm thread pitch.
Old 05-16-2015, 09:02 AM
Brando
quattrorunner's Avatar
I'd love to see a gauge with six readouts.
this is cool.
http://www.ebay.com/itm/Aersopace-Logic-6-cylinder-EGT-gauge-ASL-EGT100-/331552214070?hash=item4d320d4c36&vxp=mtr
Turbo powa!
1977 911s. it's cool
Old 05-16-2015, 09:45 AM
Turbofrog
smurfbus's Avatar
I have also thought about it but havent found any sensors that fit straight up. It would need some adapters and the electronics to log the data would cost pretty much also. I think I will settle for hand held temp meter for now as I dont think I would need that data all the time anyway. Logging AFR from those ports would be interesting too but again it would need some adapters to work.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 05-16-2015, 09:46 AM
plus 1
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 05-16-2015, 09:47 AM
kenikh's Avatar
The Audi 2.7T uses an EGT that is M12x1mm. Easy to machine in. Haven't found one @M10x1mm yet.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-16-2015, 01:38 PM
http://www.amazon.com/gp/aw/d/B00LCWRRE2/ref=mp_s_a_1_7?qid=1431817316&sr=8-7&pi=AC_SX110_SY165_QL70&keywords=egt+sensor&dpPl=1&dpID=41o3oem50fL&ref=plSrch
Old 05-16-2015, 03:01 PM
I believe an adruino could be programmed to display 6 EGT's with a little work.
Old 05-16-2015, 03:09 PM
Kartoffelkopf
Spenny_b's Avatar
I'm just running 2x EGT's, one per secondary equidistant from the primary>secondary merge collector; came into their own when mapping a few weeks ago. The sensors I use are the same as the Zeitronix units use ---> EGT Probe & 8 foot extension (K-type plug) - EFI-Parts.co.uk: Connectors, Sensors, Trigger wheels, Wideband, Adaptronic, Zeitronix, AEM
The thread for this type is 1/8" NPT.
I then run them through a 4-channel AEM thermocouple amplifier to output a signal suitable for my ECU; of course for CIS you won't need this (but somebody in future might...)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 05-16-2015, 03:19 PM
Turbofrog
smurfbus's Avatar
The Audi 2.7t EGT is not readable on audi ecus before 945C ( cant recall if they gave meaningfull data though for other ecus) but Audi RS6 C5 EGT sensor reads from iirc 50c all the way up to 1100C and I have encoded those for my ecu on my S4. Innovate has stuff to gather the EGT logs quite nicely too and you can route the data for ie. Ms3 too to use as trim data on full sequental.
Old 05-16-2015, 08:54 PM
Forced Induction Junkie
WERK I's Avatar
Don't EGT probes have relatively slow response times?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-17-2015, 04:33 AM
Kartoffelkopf
Spenny_b's Avatar
Quoting from memory about previous conversations with my pal who looks after my mapping; yes, versus Lambda control it's not quite as quick, so best used as a cross-check rather than an absolute measure.
(again, quoting from memory; always secondary to my looks, and that's dismal at best )
Old 05-18-2015, 04:45 AM
Porsche 935's Avatar
I run 6 egt sensors. It has an aircraft monitoring unit than scans each cylinder and will show you if any cylinder is more than 50 degrees off. But sensors had to be in flame travel area, I believe 1 1/2 inches from head in each exhaust pipe. My EFI system and lean or enrich cylinders as needed. Bought from chief aircraft. Sensor leads can be made to length.
Old 05-18-2015, 11:55 AM
Smart quod bastardus
fredmeister's Avatar
Yes I concur.
You can use an 1/8 inch pipe thread in those ports since it is 1/8 inch by 27 threads per inch which is pretty damn close to M10 by 1mm.
you might even run a 1/8 pipe tap thru there first to create a better fit.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 05-18-2015, 12:20 PM
copbait73's Avatar
Typical T/Cs are shielded and have slow reaction time however you can buy open junction T/Cs which are virtually instantaneous. I used open junction in the days before air fuel ratio monitoring was available.......and in many aircraft.
Old 05-18-2015, 12:36 PM
930T Owner
Hams930T's Avatar
Possible but seems like overkill
Hams930T
2017 Turbo S
Old 05-19-2015, 12:05 PM
I like the Arduino idea, although I think a Pi might be a better choice. With a Pi you can easily log the data to a USB thumb drive or send it via WiFi without adding shields etc. With the Pi you could easily add some additional sensors to your data logging as well, RPM, AFR, CHTs and so forth.
I'm putting an EFIS in the plane right now that does all this. I know from past experience the data is very useful for tuning and diagnostic purposes.
Old 05-20-2015, 12:04 PM
