-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   930 Track Sparkplug Recommendation (http://forums.pelicanparts.com/showthread.php?t=876225)
jimmcc 07-24-2015 08:22 PM
Looking for the best plug for 930 track use.
1980 930
Stock turbo .8 bar
Stock CDI
SSI Headers, no muffler
I'm assuming a colder plug like the NKG BR8EIX is a good choice.
Recommendations?
And, what should the gap be set at for stock CDI.
Jim
1980 930
1995 993
T77911S 07-27-2015 05:57 PM
dont think i would use the iridium. the CS plug is a good one. dont know how many are running the coppers.
8 or 9. start with a 9
Dave 86 930 Fl 07-28-2015 03:55 AM
I've run stock plugs for years, no issues or complaints. $16 each from our host.
Hams930T 07-28-2015 07:15 AM
I use a Denso IW-24 which is their heat range 8 iridium plug. They also make a racing version of that plug but I've found the standard iridium version is pretty awesome.
pkracer21j 07-28-2015 07:34 AM
I run copper resistor autolites, equivalent heat range of a 9. gapped at 23 thousandths
Speedy Squirrel 07-28-2015 12:05 PM
Don't torture your poor little stock CDI with a resistor plug. It will just get even hotter than normal, and deliver less energy at the gap.
Why change from a 0.2mm platinum electrode to a .4mm copper electrode? Seems like the wrong direction to me.
WinRice 07-28-2015 12:51 PM
+1
or use the IK-24 with a smaller 5/8" hex. Easier to change.
jimmcc 07-30-2015 07:38 AM
Thanks guys.
I'm bringing a 1980 930 back to life and want to update the plugs. My former mechanic used some Champion from a long time ago. The car has been idle for over 10 years so is getting the fuel system and mechanical go over before restarting.
Lot's of opinions to consider here.
Jim
1980 930
1995 993
