Btw, do you mean crank sensor when you have written TPS sensor? TPS is throttle position sensor and the crank sensor is for ignition no? Just to clarify.
I've been off the board for a few weeks, nice work!!
Welcome to the darkside! Can you add EBC? I am running a Tech3 with EBCS, but I am going to change out my Tech3 for a VEMS, so I can do COP and boost per gear, my car is useless with 1.3bar in 2nd (1st is for parking). |
MSPro can do just about anything! :) |
Then I need to plumb in the Flex fuel sensor as well as replace all the rest of the fuel lines with e85 compatible hose. If I can find a compatible VSS signal then the boost by gear and traction control feature would be pretty handy as well. |
I have antilag (MS calls launch control) on my MSII.
I can hit full boost at a stoplight. Not that I've tried full boost, but 1 bar came quick at half throttle, so I chickened out and let off. Can you PM me the III and X prices, please? Thanks in advance. |
Dos531,
Again thanks so much for this wonderful bit of information! I was messing with your spreadsheet a little bit, and I noticed that your Total does not include the: Crank Trigger Coils Coil connectors Knock Sensor Not hard to fix on our own, but just wanted to share that with you. Again Thanks! Rich |
Great job if you are bored now you can come over and do it to my car.
thanks! |
I'm interested in where you mounted the MS3-Pro. In the engine compartment? They say it can handle the heat, but I'm not 100% convinced.
The fan shroud blows hot air straight down out of compartment while engine tin blocks the radiant heat from coming up pretty good. It should be just fine. |
I am using pretty much same set up - GSF crank wheel and same VR sensor so am interested in knowing what air gap do you set with the sensor?
I had been chasing a high load/high RPM misfire and now 100% dead in the water as I started fiddling with the VR sensor (thinking it may be bad). Now can't even get MS3 to sync... In fact, wondering if I had blown something in the HW so may need replacement :( |
Mine was running for a season but continued to have issue at high boost/high RPM and I never had sync loss as well before. But after trying to replace the VR sensor I can't even get her to sync anymore 😔 |
| All times are GMT -8. The time now is 06:20 PM. |
