Where did you source the capacitor?
^^^ In scanning the MS3Pro manual today I believe they noted that you can use a condenser from an old-fashioned ignition points system.
I'll add it to the excel file |
I also offer engine management systems for Porsches, both plug and play and wire in ones. VEMS works perfectly with any original 911 crank trigger (3.2 dual VR ones with 129+1 teeth, 964/993 60-2 etc) or with aftermarket one, no issues with signal or noise.
Here's my FB page, check out the photos etc: www.facebook.com/vemsporsche https://scontent-arn2-1.xx.fbcdn.net...90149527_o.jpg https://scontent-arn2-1.xx.fbcdn.net...19586899_o.jpg |
Looks like a cool system but i would make your own thread about it and give it the attention it needs. Better having all the Q&As in a dedicated thread with additional info. SmileWavy
The Summit fuel line is for between the rails yes? Feed line goin in one and return line out the other?
IAT drilled and tap in cam tower? So many questions :) |
IAT should be in the intake air, not touching any engine metal (it will just heatsoak).
so you just cut the lenght for each position.. got it :)
| All times are GMT -8. The time now is 06:20 PM. |
