Me like track days
3.4 HP/TQ - what did you get?
3.4 HP/TQ - what did you get? I got 438/413 at the wheels on Dynojet at .9 bar
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Values are with 0.9 Bar Spring and measured at the crank.
452.7 PS and 423ft/lbs (Bosch FLA 206) Mahle P/C 3.4 7.5:1 964 Cams Intercooler Longneck from Turbokraft Tial Wastegate 0.9 Bar Spring Headers with heat port size 38mm from Rarly8 Turbocharger K27/29 from Rarly8 WUR & RPM switch,CIS Injector Blocks port size 36mm from Turbokraft Flyweel Clutch Set from Patrick Motorsport Supertec Head Studs and Engine Seal Kit
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods Last edited by 930/66; 12-10-2015 at 01:24 PM.. |
Chain fence eating turbo
You guys on stock 930 heads?
13#s boost 535/450
18#s boost 628/545 (daily driver tune) 23#s boost 706/626 lambo crusher / scarrrrry!!!!!
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp |
Me like track days
I wouldnt use 930 heads. I have 911sc heads
At 0.9 Bar on a Dynapack Dyno at the hubs 460 and a bit over 400
What parts???
Just curious, why?
Jon |
What Parts??
My set up from memory ... LN Nickies with JE's 3.4 at 8:1 Twin plug heads with the intake ports opened up to 40mm, port matched flat manifold 964 cams Brian's twin wastegate headers and a GT35R T3 V-Band exhaust housing and T4 compressor Custom intercooler by Gerhard at Bell Full sequential MegaSquirt with a bunch of Clewett parts & the biggest high impedance injectors I could find. A safe tune to ensure survival at the track. Dave |
930 Heads
Intake open to 36mm / Exhaust to 38mm
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods |
This is a really frustrating thread.
![]() Numbers without combo of parts. It's like waiving a crack rock in front of an addict telling he/she they cannot have any! Y'all are killing me. Why? Because I'm 3.4 from a 3.2 platform. I had dyno numbers, but the range was from 250whp to 770ft/lbs of torque at 1.4 bar. So, I didn't trust the numbers obviously..... ![]()
410 whp/396 tq at .8 bar on a Dynojet.... now switched to a .9 bar but no dyno yet.
Rey....77 930 "the Mistress" |
Me like track days
BIG port. SC heads are readily available as well!
Still looking for a set of 3.2 heads. Any leads are greatly appreciated.
That's quite a beast you have there Craig. I've always admired your build. Sorry to see you sell.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Me like track days
Ah thanks! It will be officially for sale in a few months, spring time frame.
There is nothing I can do to make any component newer or better, I have maximized the 930 to the best of every component, a real beast for sure and properly done (pat self on back) lol :-)
What cams??
Me like track days
SC cams
K27?
