b930's Avatar
Help with throttle linkage, 3.2 carrera manifold.
Hi
I use a stock 3.2 manifold on my 930, throttle body not rotated. I am using the 3.2 throttle body and the stock 930 linkage / bell crank on the rear of the motor.
I have a rigged up but the throttle has an overcentre feel like almost all the movement at the initial tip in, makes it hard to take off without burning the clutch!
I think I have the bell crank on the rear of the motor all wrong for the carrera manifold/TB. Should you use parallel bell crank arms when using a stock 3.2 manifold/TB? Mine is currently offset like on the 930 and I had to lengthen the long rod from the gearbox to reach it.
I have it all apart now and am able to fab up the bell crank in any orientation but wanted to check with those that may have been through this. I am trying to find stock pics of the 3.2 but from what I can tell the arms are parallel on the bell crank but still looking....
Thanks.
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 01-18-2016, 01:54 AM
Chain fence eating turbo
I can give you pics of my removed TB when I get home if that helps.
Old 01-18-2016, 04:24 AM
If this helps for now:
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-18-2016, 04:26 AM
b930's Avatar
Thanks Tippy, the pics help. That's a big throttle body, 4"?
Can you please shoot one of your linkage (bit that bolts onto rear of motor with the crank arms on it). Cheers.
Old 01-18-2016, 05:14 AM
~3"/75mm.
Let me see what I can get later, might be tough with the air filter in the way.
Old 01-18-2016, 05:44 AM
7.0:1 > 11.3:1 > 7.0:1
b930, I did the same as you back in 2006. I recall having to cut the end off the bell crank and turn it around so the ball aligned with the rod, and change the angle.
edit: I also added some material in order to have a throttle stop.
Old 01-18-2016, 09:07 AM
b930's Avatar
That's the money shot! thanks Jim.
Old 01-18-2016, 04:03 PM
