Pancake manifold frozen to stud
I'm tearing down my '79 and the intake is frozen to the pass. side middle inside stud. I haven't tried a torch yet. Are these intakes magnesium or aluminum? I've tried a heat gun and PB but no luck yet. Maybe I''ll try a double nut and try turning the stud to break it free but not sure I can get a good purchase on the bottom nut with the way it sits in an indentation in the manifold. Anyone else run into this?
Old 01-25-2016, 01:32 PM
I suggest you patience !
Leave PB overnight and try to tap the manifold with a rubber mallet...
These studs are quite long and I am not sure if it will come out easily in one piece...
Good luck,
Jim Wolf
"WHEN WE START RUNNING YOU BETTER CATCH UP"
Old 01-25-2016, 02:00 PM
Yes, the intake is magnesium. Be very careful.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 01-25-2016, 02:06 PM
Forced Induction Junkie
WERK I's Avatar
boosted,
Had the same problem getting mine off. I soaked them as suggested above, but after I eventually got the manifold off, the studs showed a calcium deposits which probably came from water getting in between the bore and the stud.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-25-2016, 04:53 PM
Well, it's encouraging that I'm not the only one. I hit with the propane and then PB numerous times and had a crow bar between a block of wood on the valve cover and another on the bottom of the manifold. I managed to get it up about a 1/4" so I called it a night. I'll let it soak and try again tomorrow. I guess the last resort will be to MIG a nut on to the stud and either back it out or break it off. I wonder what a little muriatic acid would do? It works great for cleaning aluminum off carbide burrs and aluminum off 2-stroke bores after a seize and it reacts with Mg. Maybe I'll give that a shot . I'll have a spray bottle with a baking soda mix ready to neutralize it .
Old 01-25-2016, 06:05 PM
I took mine off last night. I had to smack it with a rubber mallet several times to free it up
My studs have allot of calcium build up as well. I was planning on pulling the studs cause I'm swapping heads but, I'm probably better off just buying new ones.
Good luck.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 01-25-2016, 06:50 PM
Alan L's Avatar
The acid will LOVE your Mg manifold. I would try other methods first, and again, before plunging over the cliff.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 01-26-2016, 12:21 AM
Yes it will, it would probably do too much damage to it before it is able to get to the corroded part around the stud. I think I'll try an acetone/ATF mix on it today.
Old 01-26-2016, 05:37 AM
Time and patience and a rubber mallet.
Old 01-26-2016, 04:45 PM
I tried it again this morning with the crowbar and blocks of wood, no go. So I mixed up a 50/50 mix of acetone and ATF and let it sit for 10 minutes. Then I saw the mixture drain from around the stud which never happened with the PB. I tried the crowbar again and bingo, it came right off. Whether it was the acetone/ATF or letting the PB Blaster sit overnight I don't know but Ill be using this acetone/ATF again when I need a penetrant.
Old 01-26-2016, 07:12 PM
Alan L's Avatar
Great result.
Alan
Old 01-26-2016, 07:52 PM
WERK I's Avatar
Congrats!
Dave
Old 01-27-2016, 06:52 AM
WERK I's Avatar
boosted79,
I found this thread describing your difficulty removing the pancake manifold. Well, it has bitten me too. One stud, on #5 cylinder, inboard, is refusing to budge. The pic below shows the pool of Kroil that won't drain into the manifold stud bore. Kroil worked on all of the others, but not on this one. Do you think the 50/50 blend of acetone and ATF would work?
Dave
Old 06-08-2016, 10:27 AM
jsveb's Avatar
Can't say if it works, but I've used the ATF/ace. as well with great success
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 06-08-2016, 10:49 AM
WERK1 - All I can say is try it. I don't know if that is what did it with mine or letting it sit overnight with the PB Blaster. Rock it back and forth as much as you can too. Good luck.
Old 06-08-2016, 10:55 AM
WERK I's Avatar
Jesper & boosted79, thanks. Can't believe how much of a PIA this is. I soaked all the studs with Kroil three days ago. All but one released in one day.
I rebuilt this motor back in 2002 and did not have this much difficulty getting the manifold off.
Dave
Old 06-08-2016, 04:16 PM
Try a heat gun on the manifold . Maybe it will expand the mag. enough to break it loose.
Old 06-08-2016, 04:36 PM
Ingenieur
The lower intake is aluminum guys. Only the upper is Mg. not that it helps this situation. FYI, I used double nuts and it snapped that stud right off. Not a good thing. I wound up drilling it out and helicoiling it.
Old 06-08-2016, 05:14 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Dave, if the primary intake manifold is aluminum, like the Squirrel says (I didn't know that), then you can put a few drops of muriatic acid on there and all corrosion between the stud and aluminim will dissolve . . . just a few drops at a time, don't allow it to sit too long, and clean the surfaces right away with water after you get the manifold off.
Old 06-08-2016, 05:27 PM
WERK I's Avatar
There is no part of the intake manifold that is aluminum.....all cast magnesium, unless Speedy Squirrel is referring to the injector blocks, which I still have the bakelites.
I was able to raise the intake about 1/2", but it will rise no further....today.
Tomorrow night I will try a heat gun. If that doesn't work, I'll try a 10% solution of muratic/water....with a water squirter at the ready. Thanks for the input guys...much appreciated.
btw, the studs in the pic look like they are curved. They are not (optical illusion).
Dave
Old 06-08-2016, 06:37 PM
