Smart quod bastardus
fredmeister's Avatar
clutch pedal spring
Hey guys,
Does anyone know if the clutch pedal return spring for the 79 911SC will fit the pedal box assembly for my 79 930?
My 930 return spring broke and the new 930 clutch pedal spring is NLA and I need a replacement. I figured the 911SC part and pedal box assembly is the same----am I wrong?
thanks,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 04-20-2016, 09:28 AM
3 restos WIP = psycho
kenikh's Avatar
No definitive answer here, but it is worth trying out. I'd give it a 95% chance of being right.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-20-2016, 10:16 AM
mark houghton's Avatar
Fred, just take your broken spring on down to the local spring store a couple blocks down the road and have them make you one! (that's the line I used to use with my bro' when he was living in the land of excess California). Us small town boys suffer in that regard.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 04-20-2016, 05:16 PM
I never found that spring to do much. My car came with it missing. Replaced it and made no difference. Tensioned it and loosened it. Made no difference. It's supposed to click the clutch in place...
Old 04-20-2016, 05:41 PM
Ingenieur
Hi Fred:
Not the same. The 930 one is a slightly heavier spring, which necessitated a turnbuckle in order to get it on the pedal assembly. I stole these pictures from our host to show the difference.
Mine has been broken for years, and I guess I am used to it. It broke exactly as shown in this photo. If yours is also broken in this way. I would find someone with talent to TIG weld it back together for you. They have not been available new for a long time.
Old 04-20-2016, 06:28 PM
tops911's Avatar
I used an SC spring in my car, seems to work ok.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 04-20-2016, 10:35 PM
I have a new SC spring if you want.
PM for details
Old 04-21-2016, 02:46 PM
'78 911 Coupe
Clutch Spring installation tip: http://forums.pelicanparts.com/porsche-911-technical-forum/899723-clutch-spring-install-tip.html
Old 04-21-2016, 02:49 PM
thanks guys for the info. I ordered an 911SC spring from our host and will see shortly.
the pedal is still returning ok without it though. I just want the extra assist and backup from this one.
however it gave me a good scare when it broke on track and jammed underneath the clutch pedal causing me to slip the clutch real badly for a second or 2 when I got back on the gas hard.
thought the clutch let go on me or broke the pressure plate until I hit the pedal again and felt the resistance.
Old 04-26-2016, 08:03 AM
