Tachometer in 1978 930 not working anymore
Hi
I have a 1978 930 were the tachometer suddenly stopped working. Boost gauge still working, but tachometer shows 0 all the time. I am not sure were the wire for the tachometer goes, so if anyone have a wire diagram it would be good :) I guess I have to check the tachometer it self, and also the wire/signal. Is the signal going thru the ignition box? I have now a MSD ignition, and have seen that people having trouble with signal after installation, but this box has been in the car for 2 years now. I would be very thankful if someone could give me some tip to fix this :) Have also read something about a bad alternator could give this fault? Only problem i can se so fare is the tachometer. Everything else works perfect. Sorry for the bad english, but hopefully you will understand what i mean :) Best Regards Tor Erik |
A bad alternator can kill the tach. But usually you get a warning - the tach starts bouncing around - voltage spikes from regulator in bad alternator. You can check alternator with voltage measure at battery while engine running thru to say 2500 rpm.
The tach runs off the bk/vi wire - which feeds into the TD terminal on back of tach. This wire comes direct from CDI . So direct from CDI (thru 14 pin connector on relay panel) to TD on tach. Make sure you have 12 v at tach also. And an earth. If you loose either, tach no go also. Alan |
| All times are GMT -8. The time now is 12:12 AM. |
