930 loading up
Driving home a few knights ago and all of a sudden the car starts running like dudu,bothe fuel pumps seems to be working,so when i give it partial throttle it seems to be loading up i know its not much of a explanation the car was running perfect.Any help is welcome thanks.Kevin
Sent from my SM-N910T using Tapatalk |
That's not the most helpful description, and I know nothing about your car's setup (stock or not), but I would look at ignition system. Coil, CD box, wires, cap, rotor.
Do you have an AFR gauge or did you see black smoke? I would check fuel relay switches or check fuel pressure if you have gauges.
Thanks good idea,i will keep u guys posted.Stock cis,twin plugged coil running coil pacs
No i dont have a AFR gauge,i am looking into buying one.I no i am just chasing my tail without one...
I would start with making sure both pumps are running
Check your charging system, too.
If you have an internal regulator alternator and it starts overcharging it can wreak havoc on ignition systems. |
Bothe pumps are running i verified that,I am not sure if i have a internal regulator in the alternator.I did notice when i lift up slightly on the main harness connector the engine dies.
THAT should tell you something. fix that first and see if you still have a problem
what year is it |
Its a 78
I am almost and i say almost certain it was the main harness plug that was causing all the havoc,as of yesterday the car idles perfect no stumble on a load.I just pushed the plug in a little further into the socket.I m going to remve the plug and sand the corrosion off the pins.Thanks guys for all the help,sometimes have a hard time explaning
| All times are GMT -8. The time now is 02:46 PM. |
